EasySMX ESM-9100 Joystick Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
Past 7 Days:
28
Past 30 Days:
84
All Time:
2,108
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide demonstrates how to replace the joystick of your EasySMX ESM-9100 game controller. A probable reason for the analog sticks or joystick to stop working or start drifting is that they have experienced significant wear and tear within the controller and no longer have proper calibration. Another reason could be that they are dirty; cleaning them with isopropyl alcohol on a cloth is a more immediate solution. You may also attempt to calibrate or adjust the dead zones where possible. However, if you want a permanent fix, you should consider replacing the analog sticks on your EasySMX ESM-9100 controller. Since this will require working closely with the internal electronics, be careful not to damage them to avoid making the controller entirely unresponsive.
Before you begin this repair, ensure that the controller is unplugged from your console or PC.
Tools
    1. EasySMX ESM-9100 Joystick Replacement, Bottom Case: step 1, image 1 of 1
      • Place the controller face down on a solid surface.
      • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
      • The order does not matter.
      Ask FixBot
    2. EasySMX ESM-9100 Joystick Replacement: step 2, image 1 of 3 EasySMX ESM-9100 Joystick Replacement: step 2, image 2 of 3 EasySMX ESM-9100 Joystick Replacement: step 2, image 3 of 3
      • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
      • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
      • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
      Ask FixBot
    1. EasySMX ESM-9100 Joystick Replacement, Joystick: step 3, image 1 of 2 EasySMX ESM-9100 Joystick Replacement, Joystick: step 3, image 2 of 2
      • Firmly pull off the two analog sticks (joysticks) from the potentiometers.
      • Be careful when removing the analog sticks as excessive force can cause damage to the potentiometer.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
5 other people completed this guide.
Alex Vala
858 Reputation
6 Guides authored
1 Guide Comment
جديد
ربط واير
ايهم ذولفقار - Reply Share
Past 24 Hours: 1
Past 7 Days: 28
Past 30 Days: 84
All Time: 2,108
