EasySMX ESM-9100 Face Buttons Replacement
    1. EasySMX ESM-9100 Face Buttons Replacement, Bottom Case: step 1, image 1 of 1
      • Place the controller face down on a solid surface.
      • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
      • The order does not matter.
      Ask FixBot
    2. EasySMX ESM-9100 Face Buttons Replacement: step 2, image 1 of 3 EasySMX ESM-9100 Face Buttons Replacement: step 2, image 2 of 3 EasySMX ESM-9100 Face Buttons Replacement: step 2, image 3 of 3
      • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
      • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
      • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
      Ask FixBot
    1. EasySMX ESM-9100 Face Buttons Replacement, A/B/X/Y Buttons: step 3, image 1 of 2 EasySMX ESM-9100 Face Buttons Replacement, A/B/X/Y Buttons: step 3, image 2 of 2
      • Gently pull out the buttons by the rubber backing from the top cover.
      • Be gentle so the buttons don't fall off the rubber back as you pull it out.
      Ask FixBot
    2. EasySMX ESM-9100 Face Buttons Replacement: step 4, image 1 of 2 EasySMX ESM-9100 Face Buttons Replacement: step 4, image 2 of 2
      • Gently pull each face button off of the rubber backing.
      • The buttons should be on the rubber in order of Y at the top, B to the right, A at the bottom, and X to the left.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
Alex Vala
858 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 67
All Time: 1,019
