Up to 20% off select tools
EarStudio ES100 Battery Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
30
Past 30 Days:
126
All Time:
3,819
Comments: 6
6 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Very easy
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Radson EarStudio ES100 is a Bluetooth high fidelity audio adapter. It's powered with a 3.7V 350mAh LIPO battery ref SL572035 (discontinued).
With time this battery may not work properly and prevent the adapter to be turned on. Replacement is quite easy and an alternative battery reference exists : 602035PL (with 500 mAh power)
    1. EarStudio ES100 Battery Replacement, Back panel removal: step 1, image 1 of 2 EarStudio ES100 Battery Replacement, Back panel removal: step 1, image 2 of 2
      • To open the device, push hard on the back panel corner close to the 3.5mm jack with the iFixit opening tool. Take care: the back panel will open suddenly
      • Gently push the pack panel up on all sides of the device
      Ask FixBot
    2. EarStudio ES100 Battery Replacement, Opening: step 2, image 1 of 1
      • Flip the back panel aside the device. You can now access the battery cable you can safely desolder.
      Ask FixBot
    3. EarStudio ES100 Battery Replacement, Battery reference: step 3, image 1 of 1
      • The original battery reference SL572035 is discontinued. You can replace it with an alternative battery reference, like the 602035 (3.7 V, 500 mAh) you can find and most spare part markets
      • Warning: do not mismatch with the 602535 battery with a 600 mAh capacity but larger than the 500 mAh one (25 mm versus 20 mm). Make sure the battery size is approximately 20 x 35 x 6 mm.
      • Translation issue. The part section of this article indicates the replacement battery is not available. Actually, it is. Link: https://www.aliexpress.com/item/40010454...
      Ask FixBot
To reassemble the device, glue the battery on the original tape, put the back panel in place making sure not to place it upside-down. Push hard the back panel to clip it to the device main body on all sides. Proceed to a full charge before use.
5 other people completed this guide.
Special thanks to these translators:
fr en
100%
Maxime is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Maxime
285 Reputation
1 Guide authored
6 Guide Comments
I see 602035 batteries on AliExpress that claim to also be 20x35x6mm but now up to 800mAh. Those would work too for over double the original battery life?
Andrew Kachaniwsky - Reply Share
Yes it will work. I'm using the same battery
Harv - Reply Share
They appear to be fake; the maximum capacity in that size is 450mAh.
Emilio Alvarez Garcia - Reply Share
Just replaced the battery with a 18650 one. Now it'll never die and I can hotswap it if need be :)
Mr. Trvp - Reply Share
How did you do this, got any images?
Abe Alexander - Reply Share
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 126
All Time: 3,819
