EVGA x17 Scroll Wheel Replacement
    1. EVGA x17 Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 1
      • Remove the mouse skates to reveal 5 screws.
      Ask FixBot
    2. EVGA x17 Scroll Wheel Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the 5 screws that secure the bottom panel.
      Ask FixBot
    3. EVGA x17 Scroll Wheel Replacement: step 3, image 1 of 1
      • Remove the weight chamber cover.
      Ask FixBot
    4. EVGA x17 Scroll Wheel Replacement: step 4, image 1 of 1
      • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
      Ask FixBot
    5. EVGA x17 Scroll Wheel Replacement: step 5, image 1 of 2 EVGA x17 Scroll Wheel Replacement: step 5, image 2 of 2
      • Remove the 13 screws on the interior.
      • There are 2 Phillips truss-head tapping screws, large circular heads, and the 11 Phillips screws from the interior.
      Ask FixBot
    6. EVGA x17 Scroll Wheel Replacement: step 6, image 1 of 1
      • Carefully slide middle section out.
      Ask FixBot
      • Remove smaller sized cross head screws from piece labeled AZAC001-A V1.0.
      Ask FixBot
    7. EVGA x17 Scroll Wheel Replacement: step 8, image 1 of 1
      • Pull the transistor from the side of the mouse wheel.
      Ask FixBot
    8. EVGA x17 Scroll Wheel Replacement: step 9, image 1 of 1
      • Carefully slide a spudger between the opaque plastic that holds the scroll wheel in place.
      • Pry the plastic away from the wheel, allowing for the scroll wheel to be removed.
      Ask FixBot
    9. EVGA x17 Scroll Wheel Replacement: step 10, image 1 of 2 EVGA x17 Scroll Wheel Replacement: step 10, image 2 of 2
      • Remove scroll wheel cover and replace plastic wheel (or cover if that appears to be the issue).
      Ask FixBot
2 Guide Comments
Is there a wheel that can be purchased that will fit or can be modified to fit for the replacement.
Ronald Winfrey - Reply Share
The only solution I've found so far is to 3D print the wheel. Now, my X17 mouse is working.
Carlos Pavon - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 69
All Time: 2,949
