EVGA x17 Disassembly and Cleaning
  1. EVGA x17 Disassembly and Cleaning, EVGA x17 Disassembly and Cleaning: step 1, image 1 of 1
    • Remove the mouse skates to reveal 5 screws.
    Ask FixBot
  2. EVGA x17 Disassembly and Cleaning: step 2, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 5 screws that secure the bottom panel
    Ask FixBot
  3. EVGA x17 Disassembly and Cleaning: step 3, image 1 of 1
    • Remove the weight chamber cover and clean with a Q-tip or soft fabric.
    Ask FixBot
  4. EVGA x17 Disassembly and Cleaning: step 4, image 1 of 1
    • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
    • Use a Q-tip or soft fabric to clean the bottom panel.
    Ask FixBot
  5. EVGA x17 Disassembly and Cleaning: step 5, image 1 of 1
    • Remove the 13 screws on the interior.
    • There are 2 Phillips truss-head tapping screws, large circular heads, and the 11 Phillips screws from the interior.
    Ask FixBot
  6. EVGA x17 Disassembly and Cleaning: step 6, image 1 of 2 EVGA x17 Disassembly and Cleaning: step 6, image 2 of 2
    • Once all screws are removed, carefully slide the middle section out and clean with a Q–tip or soft fabric.
    • Clean the top panel with a Q-tip or soft fabric.
    • Optional: you can remove clickers as well and clean them.
    Ask FixBot
    • Remove the smaller sized cross head screws from the piece labeled A29N001-C V1.0 RU 94V-0. Remove truss head tapping screws from the side of the mouse wheel.
    • Remove 4 screws from the piece labeled AZAC001-A V1.0.
    Ask FixBot
  7. EVGA x17 Disassembly and Cleaning: step 8, image 1 of 1
    • Pull transistor from the side of the mouse wheel.
    Ask FixBot
  8. EVGA x17 Disassembly and Cleaning: step 9, image 1 of 1
    • Carefully slide a spudger between the opaque plastic that holds the scroll wheel in place.
    • Pry the plastic away from the wheel, allowing for the scroll wheel to be removed.
    Ask FixBot
  9. EVGA x17 Disassembly and Cleaning: step 10, image 1 of 2 EVGA x17 Disassembly and Cleaning: step 10, image 2 of 2
    • Remove the scroll wheel cover and replace plastic wheel (or cover if that appears to be the issue.) Clean both with Q-tip or soft fabric.
    Ask FixBot
1 Guide Comment
Thanks for this walkthrough!
Tim Sharp - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 84
All Time: 3,627
