Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
EQ700 Side Cover Removal
View statistics:
Past 24 Hours:
9
Past 7 Days:
61
Past 30 Days:
231
All Time:
653
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows the removal of the top cover on the depicted EQ700. For this, loose parts are removed and the screws behind the display unit are made accessible. It does not describe any further repair.
      • Remove all loose components
      • Drip tray
      • Bean hopper lid
      • water tank
      • Milk tube
      Ask FixBot
      • To reach all the screws needed to expose the internal components, it is important to tilt the display assembly forward.
      • Use a thin flathead screwdriver and carefully insert it into the recesses under the display. (Work without force)
      • By applying light pressure to the sides, the clips in the recesses will release and the display assembly will tilt forward.
      Ask FixBot
      • Release the 2 screws on the bean hopper
      • Release the 2 screws behind the display
      • Release the top cover
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Author
with
extiji
369 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 61
Past 30 Days: 231
All Time: 653
