EPOS Sennheiser GSP 302 Volume Control Potentiometer Replacement
  1. EPOS Sennheiser GSP 302 Volume Control Potentiometer Replacement, Earpad Cushion: step 1, image 1 of 3 EPOS Sennheiser GSP 302 Volume Control Potentiometer Replacement, Earpad Cushion: step 1, image 2 of 3 EPOS Sennheiser GSP 302 Volume Control Potentiometer Replacement, Earpad Cushion: step 1, image 3 of 3
    • Hold the headset firmly with one hand.
    • Grip the edge of the earpad with your fingers.
    • Gently pull the earpad outward.
    • Work your way around the earpad, rotating it 360 degrees until it separates from the headset.
    Ask FixBot
  2. EPOS Sennheiser GSP 302 Volume Control Potentiometer Replacement, Speaker Driver: step 2, image 1 of 2 EPOS Sennheiser GSP 302 Volume Control Potentiometer Replacement, Speaker Driver: step 2, image 2 of 2
    • Gently scratch at the edge of the protective fabric layer covering the driver.
    • Carefully pull the fabric layer off, being mindful not to damage it in the process.
    Ask FixBot
  3. EPOS Sennheiser GSP 302 Volume Control Potentiometer Replacement: step 3, image 1 of 3 EPOS Sennheiser GSP 302 Volume Control Potentiometer Replacement: step 3, image 2 of 3 EPOS Sennheiser GSP 302 Volume Control Potentiometer Replacement: step 3, image 3 of 3
    • Remove the four 7.0 mm screws holding the speaker driver in place with a Phillips #1 screwdriver.
    • Carefully disconnect the speaker driver from the earcup by desoldering the connection with a soldering iron.
    Ask FixBot
  4. EPOS Sennheiser GSP 302 Volume Control Potentiometer Replacement, Volume Control Potentiometer: step 4, image 1 of 2 EPOS Sennheiser GSP 302 Volume Control Potentiometer Replacement, Volume Control Potentiometer: step 4, image 2 of 2
    • Remove the four 5.9 mm screws holding the volume control potentiometer in place with a Phillips #1 screwdriver.
    • Remove the volume control potentiometer from the earcup.
    Ask FixBot
TJ Graber
485 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 115
