ELENCO XP-720K Voltage Control Potentiometers Replacement
  1. ELENCO XP-720K Voltage Control Potentiometers Replacement, Remove old potentiometers: step 1, image 1 of 3 ELENCO XP-720K Voltage Control Potentiometers Replacement, Remove old potentiometers: step 1, image 2 of 3 ELENCO XP-720K Voltage Control Potentiometers Replacement, Remove old potentiometers: step 1, image 3 of 3
    • UNPLUG Power Supply from any external power and disconnect all cables.
    • Remove the two #1 philips head screws from the sides of the power supply.
    • Take a photograph of your wiring before starting to make sure you get them back correct.
    • Using your desoldering equipment desolder the 4 leads going to the two voltage control potentiometers.
    • Remove the 2 potentiometers and all their hardware.
  2. ELENCO XP-720K Voltage Control Potentiometers Replacement, Install new potentiometers: step 2, image 1 of 3 ELENCO XP-720K Voltage Control Potentiometers Replacement, Install new potentiometers: step 2, image 2 of 3 ELENCO XP-720K Voltage Control Potentiometers Replacement, Install new potentiometers: step 2, image 3 of 3
    • To fix this it was a simple fix of replacing the 2K Ohm standard potentiometers for voltage adjustment with a 10 turn precision potentiometer.
    • Insert the new potentiometers in their places.
    • Solder all four wires back to each post.
    • Put new 10 turn knobs on the front.
    • Plug power supply in and test functioning.
    • Put cover back on with four #1 philips screws.
    • You are done.
You are replacing VR1 & VR2 which are the 2 K voltage adjustment potentiometers for the variable power supplies. See page 18 of the pdf
Link to part on Amazon. https://www.amazon.com/dp/B07MQ7R5C7/?co...
Attached Documents
rickwag
1,641 Reputation
13 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 141
