This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
This guide shows you how to replace the battery of an EKIMIA PULSAR (Clevo NL41), once the lower housing has been removed.
Turn off the PC.
Unscrew the 12 screws at the bottom using a Phillips screwdriver.
NOTE: When you unscrew the green marked screws, keep your screwdriver at a 90° angle to the PC surface.
To reassemble your device, follow the instructions in reverse order.
