Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
ECAM 350.55 Test mode
Views: 17K
View statistics:
Past 24 Hours:
8
Past 7 Days:
141
Past 30 Days:
779
All Time:
17,144
Comments: 13
13 comments on steps.
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Setting the ECAM models with touch display to test mode is a little tricky. These instructions show you how to do this on the ECAM 350.55, but this guide will also work for other ECAM models, such as the 370.70. You can use the test mode to quickly check the function of the most important components. For models with "real" buttons, see here.
    1. ECAM 350.55 Test mode, ECAM 350.55 Test mode: step 1, image 1 of 3 ECAM 350.55 Test mode, ECAM 350.55 Test mode: step 1, image 2 of 3 ECAM 350.55 Test mode, ECAM 350.55 Test mode: step 1, image 3 of 3
      • When the machine is switched on, press the off-switch until the machine goes into standby mode and the display turns off.
      • There has to be water in the water tank, the drip tray is initially still inserted. The power plug remains in the outlet.
      Ask FixBot
    2. ECAM 350.55 Test mode: step 2, image 1 of 2 ECAM 350.55 Test mode: step 2, image 2 of 2
      • Pull the drip tray out a little, a corresponding message will appear on the display. (In the picture in English)
      • If you have trouble starting the test mode, leave the tray in for now and only pull it out after the next step.
      Ask FixBot
    3. ECAM 350.55 Test mode: step 3, image 1 of 3 ECAM 350.55 Test mode: step 3, image 2 of 3 ECAM 350.55 Test mode: step 3, image 3 of 3
      • First press and hold the ESC button, then press and hold the remaining three buttons in the other corners simultaneously.
      • SELECT TEST MODE" will appear on the display. Push the drip tray back in
      • Press the "DRINK MENU" button
      Ask FixBot
    4. ECAM 350.55 Test mode: step 4, image 1 of 3 ECAM 350.55 Test mode: step 4, image 2 of 3 ECAM 350.55 Test mode: step 4, image 3 of 3
      • You can now test various functions:
      • Brew group up/brew group down
      • Ev2 = solenoid valve2 clicks (upper 3-way valve)
      • Ev1 = solenoid valve1 clicks (lower 3-way valve)
      • Grinder is running
      • Coffee heater gets hot
      • Steam heater
      • Pump is running
      Ask FixBot
Work through the steps in reverse order to reassemble your device.
8 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
VauWeh
349,015 Reputation
323 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
47 Members
7,154 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 141
Past 30 Days: 779
All Time: 17,144
