Up to 20% off select tools
ECAM 2XXX test mode
Views: 9.5K
View statistics:
Past 24 Hours:
11
Past 7 Days:
109
Past 30 Days:
465
All Time:
9,474
Comments: 2
2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
ECAM 2XXX test mode
Introduction
Go to step 1 ↓
You can use the test mode to check whether the most important components of the machine are working. The instructions apply in one way or another to most models with “real” buttons; if there is a display, you will receive a corresponding display. For models with touch see here.
    1. ECAM 2XXX test mode, ECAM 2XXX test mode: step 1, image 1 of 3 ECAM 2XXX test mode, ECAM 2XXX test mode: step 1, image 2 of 3 ECAM 2XXX test mode, ECAM 2XXX test mode: step 1, image 3 of 3
      • Unplug the power cord. The switch on the back must be turned on. There must be water in the tank and all trays must be inserted.
      • Press and hold the "one cup" and "water" buttons at the same time.
      • Plug the connector back in and release the buttons.
      • The indication of the test mode appears on the display.
      Ask FixBot
    2. ECAM 2XXX test mode: step 2, image 1 of 1
      • You now can test various important components; the corresponding message appears on the display:
      • Pressing the rotary switch in the middle activates the solenoid valve 2 for the steam. (Ev2, at the top of the machine) You should hear it click.
      Ask FixBot
    3. ECAM 2XXX test mode: step 3, image 1 of 1
      • The functions for the square buttons are:
      • Both solenoid valves switch.
      • Solenoid valve 1 for the coffee (Ev1, at the bottom of the machine) switches.
      • The heater for the coffee gets warm.
      • Motor moves to the end positions and then reverses as long as the button is pressed.
      • The grinder is running.
      • The pump is running.
      • The cappuccino button at the bottom left switches the steam heater.
      Ask FixBot
Reverse the steps to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
VauWeh
349,015 Reputation
323 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
47 Members
7,132 Guides authored
2 Guide Comments
Handleiding gaat niet over machine met knoppen. Ik heb eentje met knoppen zonder display. Wat nu?
Sietske - Reply Share
ich habe eine ECAM22.366 Magnifica S Cappucino. da funktioniert es so nicht. Im Display steht weiterhin "Brühgruppe einsetzen"
Christian - Reply Share
Past 24 Hours: 11
Past 7 Days: 109
Past 30 Days: 465
All Time: 9,474
