Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
ECAM 23.xxx Test Mode
Views: 1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
35
Past 30 Days:
169
All Time:
1,040
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
With the help of test mode, you can check whether the most important components of the machine are working.
    1. ECAM 23.xxx Test Mode, Starting the test mode: step 1, image 1 of 2 ECAM 23.xxx Test Mode, Starting the test mode: step 1, image 2 of 2
      • Unplug the power connector.
      • Set the steam selector switch to 0.
      • Plug in the connector.
      • Press and hold the "Small Coffee" and "Steam" buttons simultaneously.
      • Turn on the device using the rocker switch on the back.
      • When the motor starts moving, release both buttons.
      • More detailed instructions can be found in the ECAM 23.420 Service Manual. The model is very similar to the ECAM 23.120.
      • Unplug the power connector to exit the test mode.
      Ask FixBot
    2. ECAM 23.xxx Test Mode, Prepare for testing: step 2, image 1 of 1
      • Fill the tank with water.
      • Empty the drip tray.
      Ask FixBot
    3. ECAM 23.xxx Test Mode, Testing components: step 3, image 1 of 1
      • Press the "large coffee" button. The brew unit should move to the upper end position, reverse, then to the lower end position, reverse...
      • Press the water button. The grinder should start up.
      • Press the steam button. The pump should start up.
      • Press the "P" button. The heater should get hot.
      • Press the "one cup" button. The rear solenoid valve should click audibly.
      • Press the "coffee beans" button. The lower solenoid valve (if present) should click audibly.
      • Press the power button. Both solenoid valves should click.
      • Press the "cappuccino" button (if present). The steam heater should get hot.
      Ask FixBot
If you have identified defective components, you can now repair them.
Special thanks to these translators:
de en
100%
redratchet21 is helping us fix the world! Want to contribute?
Start translating ›
Author
with
VauWeh
349,359 Reputation
324 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
47 Members
7,166 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 169
All Time: 1,040
