E-Cigarette Vaporizer Coil Replacement
  1. E-Cigarette Vaporizer Coil Replacement, Coil: step 1, image 1 of 2 E-Cigarette Vaporizer Coil Replacement, Coil: step 1, image 2 of 2
    • Pull up to remove the top cap from the IPV Mini II.
    • The unit may have hot surfaces.
    • Allow components to cool before starting.
    Ask FixBot
  2. E-Cigarette Vaporizer Coil Replacement: step 2, image 1 of 1
    • Using a Phillips head screwdriver, turn counter clockwise to loosen the positive and negative screws.
    • Be sure that the IPV Mini II is powered off before proceeding.
    Ask FixBot
  3. E-Cigarette Vaporizer Coil Replacement: step 3, image 1 of 1
    • Gently remove the burnt coil from the positive and negative screws.
    Ask FixBot
  4. E-Cigarette Vaporizer Coil Replacement: step 4, image 1 of 1
    • Place the new coil into the holes underneath the positive and negative screws.
    Ask FixBot
  5. E-Cigarette Vaporizer Coil Replacement: step 5, image 1 of 1
    • Using a Phillips screwdriver, gently turn clockwise to tighten down the positive and negative screws onto the coil.
    Ask FixBot
  6. E-Cigarette Vaporizer Coil Replacement: step 6, image 1 of 2 E-Cigarette Vaporizer Coil Replacement: step 6, image 2 of 2
    • Replace the top cap onto the IPV Mini II.
    Ask FixBot
To reverse the process, simply follow the instructions in reverse.
For more information visit https://bevapehappy.com/
12 other people completed this guide.
rzgraves
633 Reputation
1 Guide authored
Texas Tech, Team 3-4, Rauch SU 2015 Member of Texas Tech, Team 3-4, Rauch SU 2015
TTU-RAUCH-SU15S3G4
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 61
All Time: 6,352
