Up to 20% off select tools
Dyson v6 Absolute Main Body Replacement
Views: 26K
View statistics:
Past 24 Hours:
2
Past 7 Days:
52
Past 30 Days:
245
All Time:
25,611
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 7 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the motor or cyclone of the Dyson v6 Absolute is not functioning properly, the main body of the device can be removed.
    1. Dyson v6 Absolute Main Body Replacement, Bin: step 1, image 1 of 1
      • Unplug the device.
      Ask FixBot
    2. Dyson v6 Absolute Main Body Replacement: step 2, image 1 of 1
      • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
      • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
      Ask FixBot
    3. Dyson v6 Absolute Main Body Replacement: step 3, image 1 of 1
      • Push the red lever down a second time to release the debris bin.
      Ask FixBot
    4. Dyson v6 Absolute Main Body Replacement: step 4, image 1 of 1
      • Pull bin away from the cyclone.
      Ask FixBot
    1. Dyson v6 Absolute Main Body Replacement, Main Body: step 5, image 1 of 1
      • Separate the bin from the main body of the device.
      Ask FixBot
    2. Dyson v6 Absolute Main Body Replacement: step 6, image 1 of 1
      • Locate two visible white clips between the main body and the cyclone.
      Ask FixBot
    3. Dyson v6 Absolute Main Body Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to pinch the white clips together.
      • Widely hold the tweezers apart to get them to reach between the two white clips.
      • Because the space is tight between the cyclone and the main body, pinching the white clips may require additional effort.
      Ask FixBot
    4. Dyson v6 Absolute Main Body Replacement: step 8, image 1 of 2 Dyson v6 Absolute Main Body Replacement: step 8, image 2 of 2
      • Tilt and pull the main body away from the cyclone.
      • There may be a loud snap when the main body separates from the cyclone.
      Ask FixBot
14 other people completed this guide.
Author
with
Tabitha Espina Velasco
3,702 Reputation
5 Guides authored
1 Guide Comment
The motorhead does not rotate or only works irregularly?
There are two little metal tabs sitting above the lever of the bin and are meant to make electrical contact to the wires running around the bin and down the wand to the motorhead to power the rotating brush. Those metal-tabs tend to get bend and/or their ends might have become dislocated out of their brackets.
Thanks for Your guide!!! It helped me to remove the Main Body from the Cyclone properly and get those metal-tabs back in place.
Robert Hoppe - Reply Share
Past 24 Hours: 2
Past 7 Days: 52
Past 30 Days: 245
All Time: 25,611
