Tools
Introduction
Go to step 1 ↓If there are issues with the suction of the Dyson v6 Absolute, the cyclone may have to be cleaned or replaced.
Tool used on this step:Tweezers$4.99
Use tweezers to pinch the white clips together.
Widely hold the tweezers apart to get them to reach between the two white clips.
Because the space is tight between the cyclone and the main body, pinching the white clips may require additional effort.
Use the spudger to remove the cyclone.
Start at the small opening beneath the place where the cyclone connects to the main body.
Work the spudger around the rim of the red screen filter.
You will hear popping noises.
17 other people completed this guide.
3 Guide Comments
Very helpful presentation. Reassembly was fiddley as the new cyclone was not broken and needed a very firm waggle and push to engage with the motor body. The white clip is not easy to grasp at the same time as the body and the cyclone.
I found three small broken black plastic pieces under the white clip- from the lugs of the old cyclone - that had to be removed, with tweezers, before assembling the body and cyclone.
