Up to 20% off select tools
Dyson V8 Absolute Battery Replacement
Views: 224K
View statistics:
Past 24 Hours:
66
Past 7 Days:
462
Past 30 Days:
2,256
All Time:
223,770
Comments: 24
6 comments on steps, 18 guide comments.
Go to guide comments
Completed: 61
61 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 5 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
In case the device is not turning on and the battery has been completely charged for 5 hours, the battery may need to be replaced. The battery can be easily removed and replaced.
    1. Dyson V8 Absolute Battery Replacement, Battery: step 1, image 1 of 2 Dyson V8 Absolute Battery Replacement, Battery: step 1, image 2 of 2
      • Detach wand from device.
      • Use a Phillips #2 screwdriver to unscrew the screw from the device handle.
      • Screw Head Type: Phillips #2
      • Screw Length: 170mm
      Ask FixBot
    2. Dyson V8 Absolute Battery Replacement: step 2, image 1 of 3 Dyson V8 Absolute Battery Replacement: step 2, image 2 of 3 Dyson V8 Absolute Battery Replacement: step 2, image 3 of 3
      • Turn device completely over to view battery pack.
      • Below the bin, use a Phillips #2 screwdriver to remove both screws from the battery pack.
      Ask FixBot
    3. Dyson V8 Absolute Battery Replacement: step 3, image 1 of 3 Dyson V8 Absolute Battery Replacement: step 3, image 2 of 3 Dyson V8 Absolute Battery Replacement: step 3, image 3 of 3
      • Pull the battery pack down and away from the device.
      • Battery pack may fall out.
      Ask FixBot
61 other people completed this guide.
Author
with
Jasvir Dosanjh
1,959 Reputation
1 Guide authored
UW Tacoma, Team S1-G5, Rose Fall 2017 Member of UW Tacoma, Team S1-G5, Rose Fall 2017
UWT-ROSE-F17S1G5
4 Members
60 Guides authored
18 Guide Comments
Great instructions!!
akcosta60 - Reply Share
I have replaced the battery and I still got a flashing red light, any ideas
georgewaterson - Reply Share
I replaced my battery and charged the new one- my vac doesnt work
grooveon.g - Reply Share
if you have got the switch on max slide other way plug it to charge for 3,4 minuite then try should work. do not put on max as it will not work and you will have to do it all over again
anthony richards - Reply Share
My v8 animal has a new battery but it doesn't seem to want to charge. The 1st of the 3 battery lights lights up constantly, the 2nd just flashes and the 3rd never lights up no matter how long it's left on charge. The motor will run ok on the lower setting but cut's out almost instantly in the highest setting.
Could the charger be at fault?
Trunker Trubshaw - Reply Share
Past 24 Hours: 66
Past 7 Days: 462
Past 30 Days: 2,256
All Time: 223,770
