Introduction
Use this guide to replace the battery module in a Dyson V6 SV04 vacuum. The battery module, also called the battery pack or battery assembly, powers the vacuum and contains the charging circuitry and trigger switch. Replace it if the vacuum flashes red on the charger or won't hold a charge. This procedure replaces the complete module, not the individual 18650 cells inside the pack.
Step 1 Identify the failed battery and prepare safely
Unplug the charger from the vacuum and the wall outlet.
Release the trigger and keep the vacuum switched off while you work.
Step 2 Remove the dust bin
Press the bin-release latch down to open the dust bin.
Hold the latch down farther to release the bin from the vacuum body.
Wiggle the bin until the peg slides out of its slot.
Remove the bin to expose the lower battery screw.
Step 3 Remove the battery screws
Find the two Phillips screws holding the battery module.
One screw is in the lower recess exposed by the dust bin, and the other is farther back near the handle.
Use a Phillips #2 screwdriver to remove the two battery screws.
Step 4 Detach the battery module
Support the vacuum body with one hand.
Pull the battery module straight down and out through the bottom of the handle.
Don't twist the module or pull the trigger while removing it.
Step 5 Choose a replacement module
Buy a direct-plug-in Dyson V6 SV04 battery module, not loose cells, for this replacement.
Step 6 Install the replacement battery module
Align the replacement battery module with the bottom of the handle.
Press the module into the handle until it snaps in.
Step 7 Secure the battery module
Use a Phillips #2 screwdriver to reinstall the two battery screws.
Install the screw in the lower recess exposed by the bin opening.
Install the screw farther back near the handle.
Tighten the screws until snug, but don't overtighten them.
Step 8 Reinstall the dust bin
Align the dust bin peg with its slot on the vacuum body.
Slide the peg into the slot and snap the bin into place.
Close the dust bin.
Press the trigger briefly to confirm the vacuum runs.
After installing a new battery, charge it to 100%, and keep charging it for at least two more hours. Use the vacuum until it shuts off because of a low battery, then charge it uninterrupted to 100%.
The replacement battery module should now be secured and the dust bin latched. Recycle the old lithium-ion battery through a battery recycler or household hazardous waste program. Take your e-waste to an R2 or e-Stewards certified recycler. Repair didn't go as planned? Ask our Answers community for help.
