Up to 20% off select tools
Dyson V6 Motorhead Connection Tubing Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
36
Past 30 Days:
131
All Time:
2,427
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
Connection tube may get clogged with large debris picked up while vacuuming or damaged overtime.
    1. Dyson V6 Motorhead Connection Tubing Replacement, Connection Tubing: step 1, image 1 of 3 Dyson V6 Motorhead Connection Tubing Replacement, Connection Tubing: step 1, image 2 of 3 Dyson V6 Motorhead Connection Tubing Replacement, Connection Tubing: step 1, image 3 of 3
      • Depress the button releasing an end of the connection tubing.
      • Pull the connection tubing away from the bottom vacuum head.
      Ask FixBot
    2. Dyson V6 Motorhead Connection Tubing Replacement: step 2, image 1 of 3 Dyson V6 Motorhead Connection Tubing Replacement: step 2, image 2 of 3 Dyson V6 Motorhead Connection Tubing Replacement: step 2, image 3 of 3
      • Depress the last button, freeing the connection tubing.
      • Pull connection tubing away from the upper vacuum head.
      Ask FixBot
Author
with
Addie Hedge
710 Reputation
5 Guides authored
Cal Poly, Team 22-6, Maness Winter 2017 Member of Cal Poly, Team 22-6, Maness Winter 2017
CPSU-MANESS-W17S22G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 131
All Time: 2,427
