Introduction
Go to step 1 ↓Use this guide to remove, wash, dry, and reinstall the filter in a Dyson V12 vacuum. A dirty filter can restrict airflow and reduce suction. The video demonstrates an older tissue-and-brush method; the written steps below follow Dyson's current V12 washing guidance. Wash the filter monthly, or more often after vacuuming fine dust or using Boost mode frequently. The filter must be completely dry before reinstallation.
Parts
Dyson V12 HEPA Post Filter5Optional
Optional; replace the filter only if it is damaged, worn, or cleaning no longer restores performance.
Step 1 Remove the filter
Turn off the Dyson V12 and disconnect it from the charger.
Turn the filter counterclockwise and gently pull it away from the vacuum.
Step 2 Remove loose debris
Gently tap the filter over a trash bin to remove loose dust and debris before washing it.
Inspect the filter media, housing, and seal for tears, cracks, or deformation.
Step 3 Wash the pleated element
Hold the filter under warm running tap water with the foam element facing down.
Run warm water over the pleated paper element until the water runs clear.
Step 4 Wash the foam element
Keep the foam element facing down so dirty water cannot contaminate the pleated paper.
Run warm water over the inside and outside of the foam element, and gently squeeze the foam to expel dirt.
Wash the outside of the filter, fill it with warm water, cover the openings with your hands, and shake it gently.
Repeat the wash until the water runs clear.
Gently shake out excess water and leave the filter to drain with the foam element facing up.
Step 6 Reinstall the filter
Insert the completely dry filter into the vacuum.
Turn the filter clockwise until it clicks into place.
Run the vacuum briefly and check that airflow and suction have improved.
Step 7 Maintain or replace the filter
Wash the filter once a month to help maintain suction.
Use a replacement that is compatible with Dyson V12 vacuums.
After the completely dry filter is locked in place, run the vacuum briefly and check that airflow has improved. If the problem continues, ask the Dyson V12 Answers community for help.
