Introduction
Go to step 1 ↓Use this guide to remove, wash, dry, and reinstall the post-filter in a Dyson V10 vacuum. A dirty filter can restrict airflow and reduce suction. Wash the filter monthly, or more often after vacuuming fine dust or using high-power modes frequently. The filter must be completely dry before reinstallation.
Parts
Dyson V10, SV12 HEPA Post Filter5Optional
Optional; replace the filter only if it is damaged, worn, or cleaning no longer restores performance.
Step 1 Prepare the vacuum
Turn off the vacuum and disconnect it from the charger before handling the filter.
Step 2 Locate the post-filter
Hold the vacuum with the rear of the motor body facing you.
Locate the purple post-filter on the back of the vacuum.
Step 3 Remove the post-filter
Grip the purple filter housing and twist it counterclockwise to the open position.
Pull the filter straight off the rear of the vacuum.
Set the vacuum body aside in a dry place before washing the filter.
Step 4 Inspect the filter unit
Keep the filter unit assembled and gently tap it over a trash bin to remove loose dust and debris.
Check the plastic ribs, filter media, housing, and rubber seal for damage.
Step 5 Wash the inside of the filter
Hold the filter upright under cold running water and rotate it to wash the inside.
Continue rinsing until the water runs clear.
Step 6 Wash the outside of the filter
Wash the outside of the filter with cold water.
Fill the filter with cold water, cover the open end with your hand, and shake it gently.
Repeat the inside and outside rinses until the water runs clear.
Gently tap or shake the filter to remove excess water.
Step 7 Air dry the filter
Place the filter with its open end facing up in a clean area with good airflow for at least 24 hours.
Step 8 Refit the post-filter
Align the filter on the rear of the vacuum with the Dyson label at the top.
Push the filter firmly onto the back of the vacuum.
Twist the purple housing clockwise until it stops and clicks into place.
Step 9 Check the seal
Check that the filter housing sits evenly against the rear of the vacuum.
Pull gently on the filter to confirm it doesn't loosen.
Remove and refit the filter if it doesn't click, sits crooked, or shows gaps around the seal.
After the completely dry filter is locked in place, run the vacuum briefly and check that airflow has improved. If the problem continues, ask the Dyson V10 Answers community for help.
