Dyson Supersonic HD01 Motor Replacement
  1. Dyson Supersonic HD01 Motor Replacement, Unlock the filter cover: step 1, image 1 of 2 Dyson Supersonic HD01 Motor Replacement, Unlock the filter cover: step 1, image 2 of 2
    • Find the red dot along the top of the filter cover.
    • The red dot will be aligned with the white dot at the bottom of the hair dryer's handle.
    • Twist the filter cover counter-clockwise until the red dot is shifted to align with the white empty circle on the dryer handle.
    Ask FixBot
  2. Dyson Supersonic HD01 Motor Replacement, Remove the filter cover: step 2, image 1 of 2 Dyson Supersonic HD01 Motor Replacement, Remove the filter cover: step 2, image 2 of 2
    • Remove the filter cover by sliding it off of the handle.
    Ask FixBot
  3. Dyson Supersonic HD01 Motor Replacement, Remove the retaining screws: step 3, image 1 of 1
    Tool used on this step:
    T6 Torx Screwdriver
    $9.99
    Buy
    • Remove the two retaining screws at the base of the handle using a T6 Screwdriver.
    Ask FixBot
  4. Dyson Supersonic HD01 Motor Replacement, Remove the filter: step 4, image 1 of 3 Dyson Supersonic HD01 Motor Replacement, Remove the filter: step 4, image 2 of 3 Dyson Supersonic HD01 Motor Replacement, Remove the filter: step 4, image 3 of 3
    • Seperate the filter mesh at the plastic seam by pulling it apart.
    • Remove the filter mesh by sliding it off of the handle.
    Ask FixBot
  5. Dyson Supersonic HD01 Motor Replacement, Buttons: step 5, image 1 of 2 Dyson Supersonic HD01 Motor Replacement, Buttons: step 5, image 2 of 2
    • Heat the iOpener in the microwave for 30 seconds and apply it immediately to the top of the buttons.
    • Leave the iOpener in place for a couple minutes.
    Ask FixBot
  6. Dyson Supersonic HD01 Motor Replacement: step 6, image 1 of 3 Dyson Supersonic HD01 Motor Replacement: step 6, image 2 of 3 Dyson Supersonic HD01 Motor Replacement: step 6, image 3 of 3
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • Remove the buttons with tweezers.
    • Power button
    • Cold shot button
    • Use a microfiber towel soaked in rubbing alcohol to clean the button holes. Doing this will loosen the buttons if jammed.
    Ask FixBot
  7. Dyson Supersonic HD01 Motor Replacement, Motor: step 7, image 1 of 3 Dyson Supersonic HD01 Motor Replacement, Motor: step 7, image 2 of 3 Dyson Supersonic HD01 Motor Replacement, Motor: step 7, image 3 of 3
    • Pull down the cover of the hair dryer.
    • Roll the 2 O-rings down the handle and out of the way.
    Ask FixBot
  8. Dyson Supersonic HD01 Motor Replacement: step 8, image 1 of 3 Dyson Supersonic HD01 Motor Replacement: step 8, image 2 of 3 Dyson Supersonic HD01 Motor Replacement: step 8, image 3 of 3
    • Pop off the front panel of the hair dryer.
    • Flip the hair dryer 180 degrees to the back panel.
    • Remove the three 10 mm screws located on the back of the hair dryer using a T6 Torx screwdriver.
    • Remove the single T8 screw at the cable end of the back case
    Ask FixBot
  9. Dyson Supersonic HD01 Motor Replacement: step 9, image 1 of 2 Dyson Supersonic HD01 Motor Replacement: step 9, image 2 of 2
    • Flip the hair dryer back to the front panel.
    • Remove the four 10 mm screws on the front using a T4 Torx screwdriver.
    • Remove the back cover of the hair dryer.
    Ask FixBot
  10. Dyson Supersonic HD01 Motor Replacement: step 10, image 1 of 2 Dyson Supersonic HD01 Motor Replacement: step 10, image 2 of 2
    • Slide down the cover of the motor.
    • Disconnect the switch on the metal circular area towards the center of the motor.
    Ask FixBot
  11. Dyson Supersonic HD01 Motor Replacement: step 11, image 1 of 2 Dyson Supersonic HD01 Motor Replacement: step 11, image 2 of 2
    • Disconnect the switch located in the center area of the motor.
    • Slide off the black sheath on the motor.
    Ask FixBot
3 other people completed this guide.
Sophie Windover
379 Reputation
2 Guides authored
5 Guide Comments
Maybe you can help fix the problem? My Dyson Supersonic won't heat up, the company says replace it with 20% discount. But it is only a 3 year old with guarantee expired by 3 months. Is there a chance to fix expensive item? Thanks.
mario enrico rosati - Reply Share
I had a similar experience with a Karcher hand held floor washer. They said: send the silver label via mail and will replace it, but don't send item toss it. This is outrageous that these machines go in the landfill without foreign companies taking charge and try and fix them first. Happened twice, actually. Now Dyson?
I buy and repair the Dyson range of hairdryers and these are quite straightforward to repair and generally it's the same problem, either the filter(s) is blocked or the motor itself is faulty.
Mick Wild - Reply Share
I have a HD01 that do not start, it flashes white LEDs, I hear a sort of sibyl of the motor when I try to run it but at the end it do not starts. Cleaning the filter did not help... Is this a faulty motor? Where to find good replacement ones? Thanks for helping me
Dario Ferracane - Reply Share
Have you got a link for the correct motor to replace the HD01?
Yonny - Reply Share
Past 24 Hours: 8
Past 7 Days: 77
Past 30 Days: 417
All Time: 15,344
