Dyson Pure Cool AM11 Oscillation Motor Replacement
  1. Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: step 1, image 1 of 3 Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: step 1, image 2 of 3 Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: step 1, image 3 of 3
    • With the device flipped upside down, use a Phillips #1 screwdriver to remove the 4 screws holding the 3 tabs down.
    Ask FixBot
  2. Dyson Pure Cool AM11 Oscillation Motor Replacement: step 2, image 1 of 3 Dyson Pure Cool AM11 Oscillation Motor Replacement: step 2, image 2 of 3 Dyson Pure Cool AM11 Oscillation Motor Replacement: step 2, image 3 of 3
    • Remove all 3 tabs that you unscrewed.
    Ask FixBot
  3. Dyson Pure Cool AM11 Oscillation Motor Replacement: step 3, image 1 of 2 Dyson Pure Cool AM11 Oscillation Motor Replacement: step 3, image 2 of 2
    • Using a Torx T20 Screwdriver, remove the screw in the center of the base.
    • Remove the two screws connected to the rotation arm.
    Ask FixBot
  4. Dyson Pure Cool AM11 Oscillation Motor Replacement: step 4, image 1 of 3 Dyson Pure Cool AM11 Oscillation Motor Replacement: step 4, image 2 of 3 Dyson Pure Cool AM11 Oscillation Motor Replacement: step 4, image 3 of 3
    • Lift the base of the housing from the rest of the fan.
    • Be careful not to pull too hard while lifting the lower body housing as there is wires that run throughout the housing that could be damaged if too much force is used.
    Ask FixBot
  5. Dyson Pure Cool AM11 Oscillation Motor Replacement, Oscillation Motor: step 5, image 1 of 2 Dyson Pure Cool AM11 Oscillation Motor Replacement, Oscillation Motor: step 5, image 2 of 2
    • Using a T20 Torx screwdriver, remove the two screws on either side of the motor.
    Ask FixBot
  6. Dyson Pure Cool AM11 Oscillation Motor Replacement: step 6, image 1 of 2 Dyson Pure Cool AM11 Oscillation Motor Replacement: step 6, image 2 of 2
    • (Optionally) Use a jimmy around the edge of the motor to loosen it from its housing.
    • Lift the motor out of its housing.
    • Ensure that you do not grab the motor by the swing arm as you may damage both the motor and surrounding components.
    Ask FixBot
Finish Line
AidenManchester
252 Reputation
2 Guides authored
4 Guide Comments
Where’d you get the motor
Jon Murch - Reply Share
any luck finding the proper motor replacement?
Kay - Reply Share
Where get the motor ?
Tony Tone - Reply Share
I found the motor (after I fixed mine by tearing it apart messing with the gears, magnets, and wire bounding. Just starting working out of the blue. Even with a couple teeth missing). Part No.: 966943-06 on Dyson website.
Past 24 Hours: 8
Past 7 Days: 47
Past 30 Days: 251
All Time: 2,432
