Dyson Pure Cool AM11 Base Replacement
    1. Dyson Pure Cool AM11 Base Replacement, Base: step 1, image 1 of 3 Dyson Pure Cool AM11 Base Replacement, Base: step 1, image 2 of 3 Dyson Pure Cool AM11 Base Replacement, Base: step 1, image 3 of 3
      • With the device flipped upside down, use a Phillips #1 screwdriver to remove the 4 screws holding the 3 tabs down.
      Ask FixBot
    2. Dyson Pure Cool AM11 Base Replacement: step 2, image 1 of 3 Dyson Pure Cool AM11 Base Replacement: step 2, image 2 of 3 Dyson Pure Cool AM11 Base Replacement: step 2, image 3 of 3
      • Remove all 3 tabs that you unscrewed.
      Ask FixBot
    3. Dyson Pure Cool AM11 Base Replacement: step 3, image 1 of 2 Dyson Pure Cool AM11 Base Replacement: step 3, image 2 of 2
      • Using a Torx T20 Screwdriver, remove the screw in the center of the base.
      • Remove the two screws connected to the rotation arm.
      Ask FixBot
    4. Dyson Pure Cool AM11 Base Replacement: step 4, image 1 of 3 Dyson Pure Cool AM11 Base Replacement: step 4, image 2 of 3 Dyson Pure Cool AM11 Base Replacement: step 4, image 3 of 3
      • Lift the base of the housing from the rest of the fan.
      • Be careful not to pull too hard while lifting the lower body housing as there is wires that run throughout the housing that could be damaged if too much force is used.
      Ask FixBot
Finish Line
Gregory Crimmins
109 Reputation
1 Guide authored
UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023 Member of UMass Dartmouth, Team 2-7, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G7
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 102
All Time: 1,310
