Up to 20% off select tools
Dyson DC58 Battery Pack Replacement
Views: 203K
View statistics:
Past 24 Hours:
15
Past 7 Days:
79
Past 30 Days:
322
All Time:
203,223
Comments: 26
7 comments on steps, 19 guide comments.
Go to guide comments
Completed: 62
62 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 5 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Check out this guide to learn how to remove the battery pack from the Dyson DC58 vacuum. If your vacuum is not charging due to a damaged or dead battery this guide will show you how to replace it!
    1. Dyson DC58 Battery Pack Replacement, Bin: step 1, image 1 of 1
      • Make sure your vacuum is unplugged.
      • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
      Ask FixBot
    2. Dyson DC58 Battery Pack Replacement: step 2, image 1 of 1
      • Locate the red lever parallel to the red trigger and on the side of the clear bin.
      Ask FixBot
    3. Dyson DC58 Battery Pack Replacement: step 3, image 1 of 1
      • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
      Ask FixBot
    4. Dyson DC58 Battery Pack Replacement: step 4, image 1 of 2 Dyson DC58 Battery Pack Replacement: step 4, image 2 of 2
      • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
      Ask FixBot
    1. Dyson DC58 Battery Pack Replacement, Battery Pack: step 5, image 1 of 2 Dyson DC58 Battery Pack Replacement, Battery Pack: step 5, image 2 of 2
      • Locate the 10mm screw on the side of the battery pack closest to the purple cyclone of the vacuum
      • Use the 2.0 Phillips head screwdriver to remove the 10mm screw
      Ask FixBot
    2. Dyson DC58 Battery Pack Replacement: step 6, image 1 of 2 Dyson DC58 Battery Pack Replacement: step 6, image 2 of 2
      • Locate the 10mm screw on the back of the handle on the opposite side of the red trigger button
      • Use the 2.0 philips head screwdriver to remove the 10mm screw
      Ask FixBot
    3. Dyson DC58 Battery Pack Replacement: step 7, image 1 of 3 Dyson DC58 Battery Pack Replacement: step 7, image 2 of 3 Dyson DC58 Battery Pack Replacement: step 7, image 3 of 3
      • Pull the base of the vacuum down, away from the main body
      Ask FixBot
62 other people completed this guide.
Author
with
Krista St Onge
2,260 Reputation
2 Guides authored
CSU Fullerton, Team 2-4, Bruce Fall 2015 Member of CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
4 Members
60 Guides authored
19 Guide Comments
I paid just £30 for a black & decker dust buster 10yrs ago & you tell me you want £60 for a replacement battery pack after 3yrs. Dyson has to do better. Your records don’t show that you agreed to replace the pack while the product was under gaurantee so this battery isn’t even 2yrs old!
lucialucia21 - Reply Share
Great illustration.
apple - Reply Share
mine isn;’t even a year old
M Donahue - Reply Share
Yup we have three stain animals in our house two are just over one year old and the other is a little over two years. None of them hold a charge anymore
swelch19673 - Reply Share
Had a dyson V8 Animal a little under two years and already needing a new battery.
Think I will go back to using a corded machine which lasts a lot longer and costs a lot less to buy. Sorry dyson but I’m not impressed.
Doug Mummery - Reply Share
Past 24 Hours: 15
Past 7 Days: 79
Past 30 Days: 322
All Time: 203,223
