Up to 20% off select tools
Dyson DC56 Motor Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
7
Past 7 Days:
20
Past 30 Days:
112
All Time:
3,450
Comments: 12
12 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The motor is the most important part of the DC56. If the vacuum stops working completely you could need to replace the motor.
    1. Dyson DC56 Motor Replacement, Battery: step 1, image 1 of 1
      • Make sure the vacuum is unplugged from charger.
      • Warning: Avoid pressing red trigger because the vacuum will turn on the device and begin suction.
      Ask FixBot
    2. Dyson DC56 Motor Replacement: step 2, image 1 of 1
      • Locate the purple button at the top of the device.
      Ask FixBot
    3. Dyson DC56 Motor Replacement: step 3, image 1 of 1
      • Separate the device with the purple button.
      Ask FixBot
    4. Dyson DC56 Motor Replacement: step 4, image 1 of 1
      • Take out the filter.
      Ask FixBot
    5. Dyson DC56 Motor Replacement: step 5, image 1 of 1
      • Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
      Ask FixBot
    6. Dyson DC56 Motor Replacement, Battery screw 2: step 6, image 1 of 1
      • Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
      Ask FixBot
    7. Dyson DC56 Motor Replacement: step 7, image 1 of 1
      • Pull the battery pack down and away from the main body and remove it from the device.
      Ask FixBot
    1. Dyson DC56 Motor Replacement, Motor: step 8, image 1 of 1
      • Take out the 10mm screw using a Phillips #1 screwdriver.
      Ask FixBot
    2. Dyson DC56 Motor Replacement: step 9, image 1 of 1
      • Use a spudger to separate the back plate covering the motor.
      • Be careful when trying to remove the motor with a metal spudger. Be sure your battery is removed before trying to fully remove the motor.
      Ask FixBot
    3. Dyson DC56 Motor Replacement: step 10, image 1 of 1
      • Use a flat spudger to loosen and remove the motor out of the vacuum.
      Ask FixBot
2 other people completed this guide.
Author
with
John Czerkawski
427 Reputation
4 Guides authored
USF Tampa, Team S10-G1, Thompson Fall 2017 Member of USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 20
Past 30 Days: 112
All Time: 3,450
