Up to 20% off select tools
Dyson DC56 Battery Replacement
Views: 13K
View statistics:
Past 24 Hours:
4
Past 7 Days:
36
Past 30 Days:
160
All Time:
12,658
Comments: 21
11 comments on steps, 10 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The battery is what makes this vacuum handheld and portable. It can keep the vacuum operational for approximately 3.5 hours.
    1. Dyson DC56 Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure the vacuum is unplugged from charger.
      • Warning: Avoid pressing red trigger because the vacuum will turn on the device and begin suction.
      Ask FixBot
    2. Dyson DC56 Battery Replacement: step 2, image 1 of 1
      • Locate the purple button at the top of the device.
      Ask FixBot
    3. Dyson DC56 Battery Replacement: step 3, image 1 of 1
      • Separate the device with the purple button.
      Ask FixBot
    4. Dyson DC56 Battery Replacement: step 4, image 1 of 1
      • Take out the filter.
      Ask FixBot
    5. Dyson DC56 Battery Replacement: step 5, image 1 of 1
      • Locate and remove the 10mm Phillips head screw using a Phillips #1 screw driver.
      Ask FixBot
    6. Dyson DC56 Battery Replacement, Battery screw 2: step 6, image 1 of 1
      • Locate and remove #000 25mm phillips screw on the reverse side of the vacuum
      Ask FixBot
    7. Dyson DC56 Battery Replacement: step 7, image 1 of 1
      • Pull the battery pack down and away from the main body and remove it from the device.
      Ask FixBot
12 other people completed this guide.
Author
with
Vu Nguyen
216 Reputation
1 Guide authored
USF Tampa, Team S10-G1, Thompson Fall 2017 Member of USF Tampa, Team S10-G1, Thompson Fall 2017
USFT-THOMPSON-F17S10G1
4 Members
60 Guides authored
10 Guide Comments
Works for the DC44 animal also. :)
Tina Willman-Hammar - Reply Share
You left out the removal of the screw above the charging port.
Mike - Reply Share
And after unscrewing the 2nd screw, you need very fine tweezers to extract it.
This experience has convinced me never to buy a Dyson product. Their manual gives no info about replacing the battery.
Loohan7 - Reply Share
Vu Nguyen and contributors should definitely go back in and REVISE these instructions to include the second screw mentioned by Mike 7/29/18. I almost broke my vacuum because I trust iFixit to vet their content. I discovered the second screw after going to another site and only saw Mike’s post after returning here to see if I missed something - I did: I didn’t read his comments!
Cliff - Reply Share
Yikes! Thanks goodness I read the comments before I too almost broke something by not removing the second screw!
Mark Nicoll - Reply Share
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 160
All Time: 12,658
