Dyson DC39 Origin Ball Wheels Replacement
    1. Dyson DC39 Origin Ball Wheels Replacement, Bin: step 1, image 1 of 3 Dyson DC39 Origin Ball Wheels Replacement, Bin: step 1, image 2 of 3 Dyson DC39 Origin Ball Wheels Replacement, Bin: step 1, image 3 of 3
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      Ask FixBot
    1. Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: step 2, image 1 of 3 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: step 2, image 2 of 3 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: step 2, image 3 of 3
      • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
      • Remove the four 18.0 mm Torx 15 screws.
      Ask FixBot
    2. Dyson DC39 Origin Ball Wheels Replacement: step 3, image 1 of 3 Dyson DC39 Origin Ball Wheels Replacement: step 3, image 2 of 3 Dyson DC39 Origin Ball Wheels Replacement: step 3, image 3 of 3
      • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
      • Hold the steering assembly base near one of the wheels.
      • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
      • Push up on the steering assembly to remove it completely from the ball housing.
      • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
      Ask FixBot
    1. Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: step 4, image 1 of 2 Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: step 4, image 2 of 2
      • Remove the 21.4 mm Torx 15 screw located at the center of the ball wheel.
      • There is one screw located at the center of each wheel.
      Ask FixBot
    2. Dyson DC39 Origin Ball Wheels Replacement: step 5, image 1 of 3 Dyson DC39 Origin Ball Wheels Replacement: step 5, image 2 of 3 Dyson DC39 Origin Ball Wheels Replacement: step 5, image 3 of 3
      • Pull the wheel away from the main body of the device.
      • This may require a lot of force. The plastic wheel may bend slightly.
      Ask FixBot
Michael Hutcheson
312 Reputation
2 Guides authored
Cal Poly, Team S23-G6, Livingston Spring 2017 Member of Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 37
All Time: 2,690
