Introduction
Go to step 1 ↓Use this guide to replace the battery in a Dyson DC34 cordless vacuum. A failed battery pack, rechargeable battery, or vacuum battery can cause the vacuum to do nothing when you pull the trigger, and the green charge light may stop turning on. The DC34 can use different battery styles, so remove the old battery and compare it before ordering a replacement.
Parts
Tools
Step 1 Identify battery failure symptoms
Pull the trigger and watch for any response from the vacuum.
Step 2 Separate the vacuum body
Press the top release lever to pop the vacuum open.
Separate the vacuum into two pieces.
Remove the air filter from the front of the vacuum.
Step 3 Remove the old battery
Use a Phillips screwdriver to remove the screw near the filter opening.
Use a Phillips screwdriver to remove the screw at the back of the battery area.
Slide the old battery out of the bottom of the vacuum.
Step 4 Match the battery style
Compare the old battery before ordering a replacement battery.
Choose a Type B battery if the old battery has a tab on top.
Choose an Type A battery if the old battery has no tab on top.
Search parts sellers or online marketplaces for a compatible Dyson DC34 battery that matches the old battery style.
Step 5 Install the replacement battery
Slide the replacement battery up through the bottom of the vacuum.
Use a Phillips screwdriver to install the longer screw in the back screw hole.
Step 6 Install the front screw
Place the front screw into the screw hole near the filter opening.
Use needle nose pliers to hold the screw and line it up if it's hard to start.
Use a Phillips screwdriver to seat and tighten the front screw.
Step 7 Reinstall the filter and close the vacuum
Reinstall the air filter in the front of the vacuum.
Fit the two vacuum pieces back together.
Press the top closed until it clicks.
Pull the trigger to confirm the vacuum works.
Step 8 Troubleshoot common issues
If the replacement battery doesn't fit, remove it and compare the top tab with the old battery.
If the front screw won't start, hold it with needle nose pliers until it sits in the hole.
If the vacuum doesn't close, remove and reinstall the filter with its tab facing up.
After installing a new battery, charge it to 100%, and keep charging it for at least two more hours. Use the vacuum until it shuts off because of a low battery, then charge it uninterrupted to 100%.
Recycle the old battery responsibly at a battery recycling location or an e-waste recycler. Take your e-waste to an R2 or e-Stewards certified recycler. Repair didn't go as planned? Ask our Answers community for help.
