Dyson DC31 Battery Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
34
Past 30 Days:
140
All Time:
355
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Video Guide This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
Use this guide to replace a dead battery in a Dyson DC31 cordless vacuum. The battery pack powers the vacuum motor and can cause symptoms like no response from the trigger or no green charging light. Dyson cordless models can use either an A style battery or a B style battery, so remove and inspect the old battery before buying a replacement. This procedure is specific to the DC31 and is similar to the DC34, DC44, and DC45, though small model differences may exist.
      • Unplug the vacuum from the charger and make sure the trigger won't be pressed while you work.
      • Work on a clean, dry surface away from liquids, heat, and loose metal objects.
      • Do not puncture, crush, open, or short the battery pack; replace it as a complete battery pack.
      • A dead battery is a common cause when the trigger does nothing or the green charge light no longer comes on.
      Ask FixBot
      • Press the top lever to release the front section of the vacuum.
      • Pull the vacuum into two pieces to expose the battery mounting area.
      Ask FixBot
      • Pull the air filter out of the front opening.
      • If you wash the filter, let it dry completely before reinstalling it.
      • Use a Phillips screwdriver to remove the front battery screw.
      • Use a Phillips screwdriver to remove the rear battery screw.
      • Keep track of the rear screw, because the longer screw goes in the back during reassembly.
      Ask FixBot
      • Slide the battery out through the bottom of the handle.
      • Inspect the top of the old battery before ordering a replacement.
      • Choose a Type B battery if the old battery has a tab on top.
      • Choose an Type A battery if the old battery has no tab on top.
      Ask FixBot
      • Buy a replacement battery that matches the A style or Type B battery removed from the vacuum.
      • Compare the new battery with the old battery before installation, especially the top tab shape.
      • Do not rely only on the vacuum model name when ordering, because compatible models can use different battery styles.
      • This battery style check also applies to similar Dyson cordless models such as the DC34, DC44, and DC45.
      Ask FixBot
      • Insert the replacement battery up through the bottom of the handle.
      • Align the battery so the screw holes line up with the handle.
      • Use a Phillips screwdriver to install the longer screw in the rear battery hole and tighten it.
      • Use needle nose pliers to position the front screw in the front hole if it is hard to start.
      • Use a Phillips screwdriver to seat and tighten the front screw.
      Ask FixBot
      • Insert the air filter into the front opening with its small tab facing up.
      • Join the two vacuum sections by placing the lower side first.
      • Press the top of the sections together until they click into place.
      • Press the trigger to confirm the vacuum runs again.
      Ask FixBot
      • Recycle the old battery pack through an approved battery recycling program.
      • Do not cut the wires or disassemble the old battery pack.
      • The internal cells and circuit board are soldered together and aren't part of this replacement procedure.
      Ask FixBot
After installing a new battery, charge it to 100%, and keep charging it for at least two more hours. Use the vacuum until it shuts off because of a low battery, then charge it uninterrupted to 100%.
Charge the new battery before normal use if it isn't already charged. Take your e-waste to an R2 or e-Stewards certified recycler. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 34
Past 30 Days: 140
All Time: 355
