Dyson DC28 Animal Air Muscle Assembly Replacement
    1. Dyson DC28 Animal Air Muscle Assembly Replacement, Sole Plate: step 1, image 1 of 1
      Tool used on this step:
      Coin
      $2.99
      Buy
      • Lay the vacuum on its side to allow for easy access to the bottom of the cleaner head.
      • Unlock the sole plate by using a quarter or other flat tool to turn the three plastic bolts counter-clockwise, as indicated on the sole plate.
      • The plastic fasteners can be damaged when using a metal tool to turn them.
      Ask FixBot
    2. Dyson DC28 Animal Air Muscle Assembly Replacement: step 2, image 1 of 2 Dyson DC28 Animal Air Muscle Assembly Replacement: step 2, image 2 of 2
      • Gently pull off the sole plate
      Ask FixBot
    1. Dyson DC28 Animal Air Muscle Assembly Replacement, Air Muscle Assembly: step 3, image 1 of 1
      • Remove the dust collector using the red button located at the top of the bin
      Ask FixBot
    2. Dyson DC28 Animal Air Muscle Assembly Replacement: step 4, image 1 of 1
      • Flip the vacuum over to allow for easy access to bottom.
      Ask FixBot
    3. Dyson DC28 Animal Air Muscle Assembly Replacement: step 5, image 1 of 3 Dyson DC28 Animal Air Muscle Assembly Replacement: step 5, image 2 of 3 Dyson DC28 Animal Air Muscle Assembly Replacement: step 5, image 3 of 3
      • Identify the 6 screws.
      • Remove the six 9mm screws using T15 Torx Screwdriver.
      Ask FixBot
    4. Dyson DC28 Animal Air Muscle Assembly Replacement: step 6, image 1 of 1
      • Gently remove the drive cover.
      Ask FixBot
    5. Dyson DC28 Animal Air Muscle Assembly Replacement: step 7, image 1 of 1
      • Remove the drive assembly.
      Ask FixBot
    6. Dyson DC28 Animal Air Muscle Assembly Replacement: step 8, image 1 of 2 Dyson DC28 Animal Air Muscle Assembly Replacement: step 8, image 2 of 2
      • Grab the hose by hard plastic base.
      • Pull firmly to remove it from the holder.
      • If you pull too hard the plastic can be ripped.
      Ask FixBot
    7. Dyson DC28 Animal Air Muscle Assembly Replacement: step 9, image 1 of 2 Dyson DC28 Animal Air Muscle Assembly Replacement: step 9, image 2 of 2
      • Firmly grab top section of the hose and remove from the holder.
      Ask FixBot
    8. Dyson DC28 Animal Air Muscle Assembly Replacement: step 10, image 1 of 1
      • Remove section of the hose from the vacuum.
      Ask FixBot
    9. Dyson DC28 Animal Air Muscle Assembly Replacement: step 11, image 1 of 2 Dyson DC28 Animal Air Muscle Assembly Replacement: step 11, image 2 of 2
      • Go to the wheel on the right side of the vacuum.
      • Remove the cap of wheel by sliding in a small metal spudger or flat head screwdriver and gently prying up.
      Ask FixBot
    10. Dyson DC28 Animal Air Muscle Assembly Replacement: step 12, image 1 of 2 Dyson DC28 Animal Air Muscle Assembly Replacement: step 12, image 2 of 2
      Metal Spudger
      $2.99
      Buy
      • Use the pointed end of a metal spudger to pull off the e-clip.
      • The e-clip is hard to remove and may require some effort to remove.
      Ask FixBot
    11. Dyson DC28 Animal Air Muscle Assembly Replacement: step 13, image 1 of 1
      • Pull the wheel off of the axel.
      Ask FixBot
    12. Dyson DC28 Animal Air Muscle Assembly Replacement: step 14, image 1 of 1
      • Remove the axel piston from axel.
      • Be careful not to lose the washer on the end of the axel piston.
      Ask FixBot
    13. Dyson DC28 Animal Air Muscle Assembly Replacement: step 15, image 1 of 1
      Flush Cutter
      $34.95
      Buy
      • Use the wire cutters to cut the zip tie holding the tube on.
      • Be careful not to cut the plastic hose.
      Ask FixBot
    14. Dyson DC28 Animal Air Muscle Assembly Replacement: step 16, image 1 of 1
      • Gently pry and pull the tube off of the nub.
      Ask FixBot
    15. Dyson DC28 Animal Air Muscle Assembly Replacement: step 17, image 1 of 1
      • Use a flat head screwdriver or metal spudger to push the plastic out of the way and remove the air muscle.
      • Be careful not to break the plastic. Bend it just enough to remove the part.
      Ask FixBot
    16. Dyson DC28 Animal Air Muscle Assembly Replacement: step 18, image 1 of 1
      • Remove the air muscle from the rest of the vacuum.
      Ask FixBot
4 other people completed this guide.
Alec Goodman
222 Reputation
1 Guide authored
Cal Poly, Team 21-4, Maness Winter 2017 Member of Cal Poly, Team 21-4, Maness Winter 2017
CPSU-MANESS-W17S21G4
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 106
All Time: 11,079
