Up to 20% off select tools
Dyson DC08 brush replacement
Views: 22K
View statistics:
Past 24 Hours:
13
Past 7 Days:
50
Past 30 Days:
236
All Time:
22,041
Comments: 17
1 comment on steps, 16 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. Dyson DC08 brush replacement, Brush: step 1, image 1 of 3 Dyson DC08 brush replacement, Brush: step 1, image 2 of 3 Dyson DC08 brush replacement, Brush: step 1, image 3 of 3
      • Take off the dust cannister.
      • Remove the suction hose.
      Ask FixBot
    2. Dyson DC08 brush replacement: step 2, image 1 of 3 Dyson DC08 brush replacement: step 2, image 2 of 3 Dyson DC08 brush replacement: step 2, image 3 of 3
      • Extract the front filter.
      Ask FixBot
    3. Dyson DC08 brush replacement: step 3, image 1 of 3 Dyson DC08 brush replacement: step 3, image 2 of 3 Dyson DC08 brush replacement: step 3, image 3 of 3
      • Extract the rear filter.
      • Unscrew the first Torx screw.
      Ask FixBot
    4. Dyson DC08 brush replacement: step 4, image 1 of 2 Dyson DC08 brush replacement: step 4, image 2 of 2
      • Optionally, remove the rear filter cover.
      Ask FixBot
    5. Dyson DC08 brush replacement: step 5, image 1 of 2 Dyson DC08 brush replacement: step 5, image 2 of 2
      • Unscrew the 2nd Torx screw.
      • Disassemble the suction hose connection (optional)
      Ask FixBot
    6. Dyson DC08 brush replacement: step 6, image 1 of 3 Dyson DC08 brush replacement: step 6, image 2 of 3 Dyson DC08 brush replacement: step 6, image 3 of 3
      • Remove the wheels.
      • The wheels clip onto the body of the appliance.
      • Unscrew the 4 Torx screws (two in the right and two on the left).
      Ask FixBot
    7. Dyson DC08 brush replacement: step 7, image 1 of 2 Dyson DC08 brush replacement: step 7, image 2 of 2
      • Open the body of the vacuum cleaner.
      • You can use a multimeter to test the switch.
      • Disconnect the brown wire at the switch.
      • Disconnect the blue wire at the single connector by the motor.
      • Lift out the motor.
      Ask FixBot
    8. Dyson DC08 brush replacement: step 8, image 1 of 2 Dyson DC08 brush replacement: step 8, image 2 of 2
      • Open the motor housing (4 clips).
      • Remover the motor from its plastic casing.
      • Disconnect the motor.
      Ask FixBot
    9. Dyson DC08 brush replacement: step 9, image 1 of 3 Dyson DC08 brush replacement: step 9, image 2 of 3 Dyson DC08 brush replacement: step 9, image 3 of 3
      • disassembly of 2 engine coals (1 Phillips screw per coal)
      Ask FixBot
    10. Dyson DC08 brush replacement: step 10, image 1 of 3 Dyson DC08 brush replacement: step 10, image 2 of 3 Dyson DC08 brush replacement: step 10, image 3 of 3
      • Worn brush.
      • Opening the brush housing.
      Ask FixBot
    11. Dyson DC08 brush replacement: step 11, image 1 of 3 Dyson DC08 brush replacement: step 11, image 2 of 3 Dyson DC08 brush replacement: step 11, image 3 of 3
      • Extraction of the brush and spring.
      Ask FixBot
    12. Dyson DC08 brush replacement: step 12, image 1 of 2 Dyson DC08 brush replacement: step 12, image 2 of 2
      • Removing the brush.
      Ask FixBot
    13. Dyson DC08 brush replacement: step 13, image 1 of 2 Dyson DC08 brush replacement: step 13, image 2 of 2
      • Soldering a new brush.
      Ask FixBot
17 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
christophe
806 Reputation
2 Guides authored
16 Guide Comments
Very useful guide - I treated myself to a new motor as the cost was not much more than the cost of replacement brushes.
Bob - Reply Share
Hi, where did you buy the new motor?
Nadja - Reply Share
Bravo, très bon tutoriel
shog shog - Reply Share
Bonjour
et si on n’a rien pour souder, y a t’il une autre solution svp?
GALLAS - Reply Share
Bonjour ! Si vous ne disposez pas de matérial de soudure, nous vous conseillons de vous rendre à un Repair Café ou un Fab Lab. Ces associations mettent du matériel à disposition et peuvent éventuellement aussi vous conseiller sur la démarche à suivre. Bonne réparation !
Claire Miesch - Reply Share
Past 24 Hours: 13
Past 7 Days: 50
Past 30 Days: 236
All Time: 22,041
