Dyson Corrale HS03 Outer Casing Replacement
  1. Dyson Corrale HS03 Outer Casing Replacement, Outer Casing: step 1, image 1 of 2 Dyson Corrale HS03 Outer Casing Replacement, Outer Casing: step 1, image 2 of 2
    • Hold the Dyson with the silver safety lock facing you and push it upward.
    • This opens the heating plates forming a "V."
    Ask FixBot
  2. Dyson Corrale HS03 Outer Casing Replacement: step 2, image 1 of 3 Dyson Corrale HS03 Outer Casing Replacement: step 2, image 2 of 3 Dyson Corrale HS03 Outer Casing Replacement: step 2, image 3 of 3
    • Use a TR6 Torx security screwdriver to remove the screw from the center of the purple hinge bracket on each side of the hinge.
    • Use a Jimmy or spudger to carefully pry up and remove the hinge brackets.
    Ask FixBot
  3. Dyson Corrale HS03 Outer Casing Replacement: step 3, image 1 of 3 Dyson Corrale HS03 Outer Casing Replacement: step 3, image 2 of 3 Dyson Corrale HS03 Outer Casing Replacement: step 3, image 3 of 3
    • Pull off the black cover from the base.
    • Use a TR7 Torx security screwdriver to remove the two screws from the base of the straightener.
    Ask FixBot
  4. Dyson Corrale HS03 Outer Casing Replacement: step 4, image 1 of 2 Dyson Corrale HS03 Outer Casing Replacement: step 4, image 2 of 2
    • With your thumb and index fingers, pull the black charging port cover off.
    Ask FixBot
  5. Dyson Corrale HS03 Outer Casing Replacement: step 5, image 1 of 3 Dyson Corrale HS03 Outer Casing Replacement: step 5, image 2 of 3 Dyson Corrale HS03 Outer Casing Replacement: step 5, image 3 of 3
    • Hold the Dyson firmly, supporting one side with one hand while using the other hand to open the opposite side.
    • Pull up on the side you want to open to release it, then repeat on the opposite side.
    Ask FixBot
  6. Dyson Corrale HS03 Outer Casing Replacement: step 6, image 1 of 2 Dyson Corrale HS03 Outer Casing Replacement: step 6, image 2 of 2
    • Use a T4 Torx screwdriver to remove the screws from the middle section.
    Ask FixBot
  7. Dyson Corrale HS03 Outer Casing Replacement: step 7, image 1 of 1
    • Use an opening tool to pop off the silver safety lock.
    Ask FixBot
  8. Dyson Corrale HS03 Outer Casing Replacement: step 8, image 1 of 3 Dyson Corrale HS03 Outer Casing Replacement: step 8, image 2 of 3 Dyson Corrale HS03 Outer Casing Replacement: step 8, image 3 of 3
    • Hold the Dyson firmly with one hand. With the other hand, push down under the black tab while pulling up at the same time to lift and remove the purple casing.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 58
All Time: 227
