Dyson Corrale HS03 Heating Elements Replacement
  1. Dyson Corrale HS03 Heating Elements Replacement, Outer Casing: step 1, image 1 of 2 Dyson Corrale HS03 Heating Elements Replacement, Outer Casing: step 1, image 2 of 2
    • Hold the Dyson with the silver safety lock facing you and push it upward.
    • This opens the heating plates forming a "V."
    Ask FixBot
  2. Dyson Corrale HS03 Heating Elements Replacement: step 2, image 1 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 2, image 2 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 2, image 3 of 3
    • Use a TR6 Torx security screwdriver to remove the screw from the center of the purple hinge bracket on each side of the hinge.
    • Use a Jimmy or spudger to carefully pry up and remove the hinge brackets.
    Ask FixBot
  3. Dyson Corrale HS03 Heating Elements Replacement: step 3, image 1 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 3, image 2 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 3, image 3 of 3
    • Pull off the black cover from the base.
    • Use a TR7 Torx security screwdriver to remove the two screws from the base of the straightener.
    Ask FixBot
  4. Dyson Corrale HS03 Heating Elements Replacement: step 4, image 1 of 2 Dyson Corrale HS03 Heating Elements Replacement: step 4, image 2 of 2
    • With your thumb and index fingers, pull the black charging port cover off.
    Ask FixBot
  5. Dyson Corrale HS03 Heating Elements Replacement: step 5, image 1 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 5, image 2 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 5, image 3 of 3
    • Hold the Dyson firmly, supporting one side with one hand while using the other hand to open the opposite side.
    • Pull up on the side you want to open to release it, then repeat on the opposite side.
    Ask FixBot
  6. Dyson Corrale HS03 Heating Elements Replacement: step 6, image 1 of 2 Dyson Corrale HS03 Heating Elements Replacement: step 6, image 2 of 2
    • Use a T4 Torx screwdriver to remove the screws from the middle section.
    Ask FixBot
  7. Dyson Corrale HS03 Heating Elements Replacement: step 7, image 1 of 1
    • Use an opening tool to pop off the silver safety lock.
    Ask FixBot
  8. Dyson Corrale HS03 Heating Elements Replacement: step 8, image 1 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 8, image 2 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 8, image 3 of 3
    • Hold the Dyson firmly with one hand. With the other hand, push down under the black tab while pulling up at the same time to lift and remove the purple casing.
    Ask FixBot
  9. Dyson Corrale HS03 Heating Elements Replacement, Battery: step 9, image 1 of 3 Dyson Corrale HS03 Heating Elements Replacement, Battery: step 9, image 2 of 3 Dyson Corrale HS03 Heating Elements Replacement, Battery: step 9, image 3 of 3
    • Pull the purple casing upward to access and remove the battery.
    • Use a TR7 Torx security screwdriver to remove the screw securing the magnetic charging port.
    • Detach the charging port.
    • When removing it, avoid pulling as it is attached to the device by a white cable.
    Ask FixBot
  10. Dyson Corrale HS03 Heating Elements Replacement: step 10, image 1 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 10, image 2 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 10, image 3 of 3
    • With a TR6 Torx security screwdriver, you will take off a singular screw.
    • This will later be an advantage when removing the black cover of the control board.
    Ask FixBot
  11. Dyson Corrale HS03 Heating Elements Replacement: step 11, image 1 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 11, image 2 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 11, image 3 of 3
    • Use a spudger or a clean fingernail to flip up the black locking flap highlighted by the red circle—in the last photo, it is in the unlocked position.
    • Use tweezers or your fingers to gently pull the white ribbon cable from the socket on the board.
    Ask FixBot
  12. Dyson Corrale HS03 Heating Elements Replacement: step 12, image 1 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 12, image 2 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 12, image 3 of 3
    • Use an iFixit opening tool, to remove the black cover, which should pop right out.
    • Use the iFixit opening tool, to take off the plastic cover leading to the control panel.
    Ask FixBot
  13. Dyson Corrale HS03 Heating Elements Replacement: step 13, image 1 of 2 Dyson Corrale HS03 Heating Elements Replacement: step 13, image 2 of 2
    • Once again, with an iFixit opening tool, take the black cover off, revealing the side part of the battery.
    Ask FixBot
  14. Dyson Corrale HS03 Heating Elements Replacement: step 14, image 1 of 2 Dyson Corrale HS03 Heating Elements Replacement: step 14, image 2 of 2
    • The Control panel will be removed using a ifixit opening tool
    • The plastic cover should now come off by simply grabbing it from the top and taking it off.
    Ask FixBot
  15. Dyson Corrale HS03 Heating Elements Replacement: step 15, image 1 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 15, image 2 of 3 Dyson Corrale HS03 Heating Elements Replacement: step 15, image 3 of 3
    • Use a TR7 Torx Security Screwdriver to remove the single screw shown in the picture.
    • This now gives you a clear view of the batteries and what you'll need for your next step.
    Ask FixBot
  16. Dyson Corrale HS03 Heating Elements Replacement: step 16, image 1 of 2 Dyson Corrale HS03 Heating Elements Replacement: step 16, image 2 of 2
    • Use a iFixit Opening Tool to remove the battery holder. Be careful, as this step can be a bit challenging.
    • Repeat this on all eight sides. Once you finish, the batteries should fall out on their own.
    • Replacing the 4-cell lithium-ion battery pack requires spot welding. For more information on this process, check out this article.
    Ask FixBot
  17. Dyson Corrale HS03 Heating Elements Replacement, Heating Elements: step 17, image 1 of 3 Dyson Corrale HS03 Heating Elements Replacement, Heating Elements: step 17, image 2 of 3 Dyson Corrale HS03 Heating Elements Replacement, Heating Elements: step 17, image 3 of 3
    • These next few steps will be really simple. Here, you can see the two heating elements.
    • Use an Tr7 Torx Security Screwdriver to remove all four nails on each plate.
    • The plates will now come off and are ready to be replaced.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 65
All Time: 478
