Dyson Ball Animal Power Cord Replacement
    1. Dyson Ball Animal Power Cord Replacement, Power Cord: step 1, image 1 of 1
      • Turn off and unplug the vacuum.
      • Remove the vacuum canister from the front of the vacuum.
      Ask FixBot
    2. Dyson Ball Animal Power Cord Replacement: step 2, image 1 of 1
      • Flip the vacuum around and remove the hose so it is not blocking the back of the vacuum.
      Ask FixBot
    3. Dyson Ball Animal Power Cord Replacement: step 3, image 1 of 3 Dyson Ball Animal Power Cord Replacement: step 3, image 2 of 3 Dyson Ball Animal Power Cord Replacement: step 3, image 3 of 3
      • There are four 15mm screws that must be removed with a Torx T15 screwdriver.
      Ask FixBot
    4. Dyson Ball Animal Power Cord Replacement: step 4, image 1 of 3 Dyson Ball Animal Power Cord Replacement: step 4, image 2 of 3 Dyson Ball Animal Power Cord Replacement: step 4, image 3 of 3
      • After all the screws are released there are two tabs that must be pressed in and towards the center.
      • The tabs can be pressed in one at a time but may require some force.
      Ask FixBot
    5. Dyson Ball Animal Power Cord Replacement: step 5, image 1 of 2 Dyson Ball Animal Power Cord Replacement: step 5, image 2 of 2
      • After removing the two tabs gently pull the face off the power supply.
      Ask FixBot
    6. Dyson Ball Animal Power Cord Replacement: step 6, image 1 of 1
      • Follow the black cord from the power cord.
      • Pinch the plastic piece.
      • Remove from the metal tongue.
      • When removing the cords, grab them from the plastic parts and not the cord.
      Ask FixBot
    7. Dyson Ball Animal Power Cord Replacement: step 7, image 1 of 3 Dyson Ball Animal Power Cord Replacement: step 7, image 2 of 3 Dyson Ball Animal Power Cord Replacement: step 7, image 3 of 3
      • There is also a black case that needs to be opened in order to remove the power cord.
      • After opening the case pull apart the wire and attach the new wire.
      • Again, make sure that you are pulling from the heads of the wires and not the wires themselves.
      Ask FixBot
4 other people completed this guide.
Jonathan Gong-Guy
348 Reputation
1 Guide authored
Cal Poly, Team S15-G5, Banghart Spring 2017 Member of Cal Poly, Team S15-G5, Banghart Spring 2017
CPSU-BANGHART-S17S15G5
4 Members
60 Guides authored
3 Guide Comments
Great tutorial! The pictures were awesome, I replaced my cord in about 15 minutes thanks to this post. The only thing you might want to add is the gray switch with the spring. Mine fell out while I was trying to put the unit back together and I had to research how it went back together correctly. Thanks again!
Jim
Jim Knox - Reply Share
I had the same spring lever issue. This video shows how to replace them.
https://youtu.be/CLk1Zu6nREk
Robert W Marvin - Reply Share
Thank you for the YouTube link on the button reassembly. I should have expected it to be sitting loaded when I disassembled it.
chuckparent - Reply Share
Past 24 Hours: 15
Past 7 Days: 82
Past 30 Days: 216
All Time: 39,681
