Up to 20% off select tools
Dyson Ball Animal Power Button Replacement
Views: 9.3K
View statistics:
Past 24 Hours:
8
Past 7 Days:
56
Past 30 Days:
204
All Time:
9,272
Comments: 2
2 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. Dyson Ball Animal Power Button Replacement, Power Button: step 1, image 1 of 2 Dyson Ball Animal Power Button Replacement, Power Button: step 1, image 2 of 2
      • Turn off and unplug the vacuum
      Ask FixBot
    2. Dyson Ball Animal Power Button Replacement: step 2, image 1 of 1
      • Press the red release button and pull the canister up and away.
      Ask FixBot
    3. Dyson Ball Animal Power Button Replacement: step 3, image 1 of 2 Dyson Ball Animal Power Button Replacement: step 3, image 2 of 2
      • Locate the red dial at the back of the wand and turn counterclockwise to detach the wand.
      Ask FixBot
    4. Dyson Ball Animal Power Button Replacement: step 4, image 1 of 2 Dyson Ball Animal Power Button Replacement: step 4, image 2 of 2
      • Remove the four 15mm screws behind the power button using a Torx T15 screwdriver.
      Ask FixBot
    5. Dyson Ball Animal Power Button Replacement: step 5, image 1 of 3 Dyson Ball Animal Power Button Replacement: step 5, image 2 of 3 Dyson Ball Animal Power Button Replacement: step 5, image 3 of 3
      • Use a spudger to push the two clamp tabs behind the power button towards the middle of the vacuum.
      Ask FixBot
    6. Dyson Ball Animal Power Button Replacement: step 6, image 1 of 2 Dyson Ball Animal Power Button Replacement: step 6, image 2 of 2
      • Detach the power box case from the body of the Dyson after both clamps have been pushed out.
      • Upon removal of this case, you will be able to see a red circular power button.
      Ask FixBot
    7. Dyson Ball Animal Power Button Replacement: step 7, image 1 of 2 Dyson Ball Animal Power Button Replacement: step 7, image 2 of 2
      • Gently pull the power button out of its slot as shown.
      • Detach the power button box from the two wires connecting it, and replace the faulty power button box with a functional one. The power button is the first black one.
      Ask FixBot
4 other people completed this guide.
Author
with
Hank Wai
166 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 56
Past 30 Days: 204
All Time: 9,272
