Dysan DC14 Duct Replacement
      • Avoid frightening the house cats.
      Ask FixBot
      • Remove dust receptacle (Cyclone Assembly) and any attachments and set aside.
      • Remove the u-bend pipe, intake cover, exhaust cover and set aside.
      Ask FixBot
      • Remove the hose assembly by releasing it from the bottom by depressing a latch via a hole through the lower half of the duct while pulling it upward.
      Ask FixBot
      • Remove the screw(s) from the power switch cover plate, found on the opposite site of the duct from the power switch. The cover plate swings away from the duct at the top, then lifts up and off. Set it and the power button aside.
      Ask FixBot
      • Pull the motor power cord out of the channel.
      • Disconnect the white wire at the connector below the power switch.
      • Pull the power switch and the wall cord that should still be attached by its black wire out of the old duct.
      Ask FixBot
      • Install the power cord and switch into the new duct.
      Ask FixBot
      • Pull both the black and white motor wires out of the opening they go through at the top of the duct. Note the location of this opening.
      • Pull the motor wires out of the channel they are embedded into all the way to the bottom.
      Ask FixBot
      • Remove the oval black rubber gasket (exhaust seal) at the top of the duct and install it on the new duct. Notice that there is a notch in the gasket that must be aligned for proper installation.
      Ask FixBot
      • Slightly below the exhaust seal is another rectangular rubber gasket (entry seal). Transfer it to the new duct, noting it too has a notch that needs to be aligned properly.
      Ask FixBot
      • You do not need to transfer the bottom most seal (exhaust pre-filter seal) over to the new duct. The part that it is installed on will be transferred to the new duct and will move with it. This step is coming up soon
      Ask FixBot
      • Remove the crevice tool clip and install it onto the new duct.
      Ask FixBot
      • Squeeze the sides of the canister latch and pull it out. Do not lose the spring behind it. Reinstall the latch and spring onto the new duct.
      Ask FixBot
      • Pry off the hubcap.
      • Remove the metal e-clip from the shaft. This clip will attempt to fly across the room and vanish from this dimension. Do not let it.
      • Pull the small metal washer and the wheel from the shaft.
      Ask FixBot
      • Slide the remaining wheel and shaft out and reinstall it and the other wheel back onto the new duct.
      Ask FixBot
      • The pivot points for the Cleaner Head assembly have two plastic Bearing Clips, the ends of which are embedded into a recess on their shafts. Pry the ends out the recess and work the clips off of the shafts.
      • Remove the large plastic washers (Cleaner Head Pivot Circlips) underneath the clips.
      Ask FixBot
      • Pull out the Motor Inlet Cover Catch. It pulls straight out and may put up a fight.
      Ask FixBot
      • Turn the unit over.
      Ask FixBot
      • Remove the sole plate by rotating the three large slotted screws a quarter turn and lifting the plate off, pivoting toward the front.
      Ask FixBot
      • Yank the flexible hose off of the Port Plate.
      Ask FixBot
      • Remove the right rear screw holding the exhaust pipe assembly.
      • Remove the exhaust pipe assembly. This is tricky. It kinda pulls up and to the right
      Ask FixBot
      • Remove the port plate. One end unsnaps then pivots out on the other end. Remember that you are disposing of the piece this is coming out of while trying to save this piece, so act accordingly.
      Ask FixBot
      • Remove the forward lock and spring by depressing the sides inward to disengage the pivots and then pulling out.
      Ask FixBot
      • Remove the valve carriage.
      Ask FixBot
      • Reinstall the valve carriage onto the new duct.
      Ask FixBot
      • Reinstall the port plate, by pivoting the widest end first, then snapping the smaller end into place.
      Ask FixBot
      • Reinstall the forward lock and spring into the new duct.
      Ask FixBot
      Ask FixBot
      • Remove the five remaining screws from the bottom of the unit.
      • Lift the Cleaner Head assembly pivot points over the tops of the shafts.
      • The old duct should now be able to come off and be disposed of. Make sure nothing removable remains on it before disposing.
      Ask FixBot
      • After removing the old duct from the motor, fit the new one to it.
      • Replace the five screws removed earlier.
      Ask FixBot
      • Reinstall the exhaust pipe assembly and screw it down.
      Ask FixBot
      • Reinstall the Motor Inlet Cover Catch. Press it firmly in until it is seated.
      Ask FixBot
      • Slide the Cleaner Head pivot points back over their pivots.
      • Reinstall the plastic washers (Cleaner Head Pivot Circlips) over the pivots.
      • Reinstall the Bearing Clips onto the pivots and seat the ends back into the recesses for them.
      • Reinstall the Hose Assembly into the base of the duct.
      • Reconnect the flexible hose for the beater bar to the port plate.
      • Reinstall the sole plate that was removed in step 18.
      Ask FixBot
      • Starting at the bottom and working upward, press the motor power cord into its channel or groove in the new duct.
      • At the top, pass the motor power cord connectors through the same hole you noted earlier, next to the switch.
      • Reconnect the white wire from the motor to the white wire from the power cord.
      • Reconnect the black wire from the motor to the terminal on the switch.
      Ask FixBot
      • Push the switch back into its slot with the plunger facing up.
      • Place the button on top of the switch
      Ask FixBot
      • Reinstall the switch cover plate by first engaging its tabs at the bottom into the new duct, then pivoting it into place. Replace the screw(s) that go in from other side of the new duct.
      Ask FixBot
      • Reinstall the u-bend pipe, intake cover, and exhaust cover.
      • Reinstall the dust receptacle (Cyclone Assembly).
      Ask FixBot
You should be done.
2 other people completed this guide.
Prof. Mayhem
523 Reputation
2 Guides authored
2 Guide Comments
Many pictures needed ie. one or two for each step.
Marybeth Weber - Reply Share
Pictures would definitely be helpful but guide was very useful regardless!
mtbm33 - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 37
All Time: 1,898
