Dymo LabelManager 280 Rear Case Replacement
    1. Dymo LabelManager 280 Rear Case Replacement, Rear Case: step 1, image 1 of 2 Dymo LabelManager 280 Rear Case Replacement, Rear Case: step 1, image 2 of 2
      • Remove battery.
      • Remove the label cassette.
      Ask FixBot
    2. Dymo LabelManager 280 Rear Case Replacement: step 2, image 1 of 2 Dymo LabelManager 280 Rear Case Replacement: step 2, image 2 of 2
      • Remove the two rubber feets
      • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
      Ask FixBot
    3. Dymo LabelManager 280 Rear Case Replacement: step 3, image 1 of 2 Dymo LabelManager 280 Rear Case Replacement: step 3, image 2 of 2
      • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
      • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
      Ask FixBot
Steven Nguyen
431 Reputation
3 Guides authored
USF Tampa, Team 6-5, Eyestone Spring 2016 Member of USF Tampa, Team 6-5, Eyestone Spring 2016
USFT-EYESTONE-S16S6G5
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 49
All Time: 1,304
