Dymo LabelManager 160 Wheelhead Replacement
Views: 6.5K
View statistics:
Past 24 Hours:
10
Past 7 Days:
46
Past 30 Days:
198
All Time:
6,487
Comments: 7
2 comments on steps, 5 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Dymo LabelManager 160 is not properly printing from Dymo D1 Label Cassettes, the wheelhead which unspools the cassettes may be not functioning. This guide leads you through the process of opening up the LabelManager and changing the wheelhead. Keep in mind that the device has loose parts.
Before you begin, make sure that your device is turned off and the battery is removed.
Parts
Tools
    1. Dymo LabelManager 160 Wheelhead Replacement, Batteries: step 1, image 1 of 1
      • Place the device face-down to access the battery compartment.
      Ask FixBot
    2. Dymo LabelManager 160 Wheelhead Replacement: step 2, image 1 of 1
      • Remove the compartment cover to reveal the batteries. Remove the 6 old batteries.
      Ask FixBot
    1. Dymo LabelManager 160 Wheelhead Replacement, Keyboard: step 3, image 1 of 1
      • To open the cartridge compartment, simply lift on the front of the device.
      Ask FixBot
    2. Dymo LabelManager 160 Wheelhead Replacement: step 4, image 1 of 2 Dymo LabelManager 160 Wheelhead Replacement: step 4, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the four 1.3mm screws from the cartridge compartment and two 1.2mm screws from the battery compartment.
      Ask FixBot
    3. Dymo LabelManager 160 Wheelhead Replacement: step 5, image 1 of 1
      • Using a spudger or other tool, lift and remove the front of the device. This should be done all around the device to ensure the two parts split correctly.
      Ask FixBot
    4. Dymo LabelManager 160 Wheelhead Replacement: step 6, image 1 of 3 Dymo LabelManager 160 Wheelhead Replacement: step 6, image 2 of 3 Dymo LabelManager 160 Wheelhead Replacement: step 6, image 3 of 3
      • Gently remove the rubber keyboard from the device.
      Ask FixBot
    1. Dymo LabelManager 160 Wheelhead Replacement, Wheelhead: step 7, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the three 1.1 mm screws from the circuit board.
      Ask FixBot
    2. Dymo LabelManager 160 Wheelhead Replacement: step 8, image 1 of 1
      • Lifting the circuit board, use a Phillips #1 screwdriver to remove the two 1.2mm screws from under the circuit board.
      Ask FixBot
    3. Dymo LabelManager 160 Wheelhead Replacement: step 9, image 1 of 2 Dymo LabelManager 160 Wheelhead Replacement: step 9, image 2 of 2
      • Proceed to lift the excess device components until the rollerblade is visible.
      Ask FixBot
    4. Dymo LabelManager 160 Wheelhead Replacement: step 10, image 1 of 1
      • With the device components exposed, gently lift the wheelhead out of the label maker.
      Ask FixBot
2 other people completed this guide.
5 Guide Comments
Group 9: Over all looks great. Pictures are great quality and hand placement in pictures. The circles and arrows should all be red. The only time the color changes is if there are different steps within a single picture.
Zachary Parker - Reply Share
thank you for the procedure, i mis one screen in the procedure how to detach display?
aslan - Reply Share
Guide does not properly address or account for parts that will simply fall out if you proceed with this course. Gears, springs, plastic bits, metal rods. I had a pile of seven or eight unknown bits, plus the plastic gears.
No photos of the gearing, or the levers that hold tension on the label ribbon. These are the parts will fall out.
All I’ve managed to do is take apart and reassemble, only to have pieces that are now out, who knows where they go. Device now gives me a label jam error when reassembled. Have no clue how the tensioner should be oriented.
Gonna move on and buy a new label maker now. Thanks for the frustration ifixit.
Christopher Warren - Reply Share
Same sad story ! I am not able to reassemble the device...
alexandreliban - Reply Share
Olá! Tenho uma impressora Dymo QX50 e não imprime. A máquina trabalha perfeitamente, desenrola a fita,(que são novas), mas não se vê a impressão, apenas um leve sombra daquilo que tentei imprime. Será que conseguem me ajudar?
Natalice Santos - Reply Share
Past 24 Hours: 10
Past 7 Days: 46
Past 30 Days: 198
All Time: 6,487
