Dygma Raise Disassembly
Video Overview
      • The great thing about our Palm Pads is that you can revive them at any point by washing them in cold water. So no need to worry about it losing its stickiness!
      Ask FixBot
      • This is the Puller's time to shine. Use the loop side to grip the keycaps from below, then gently pull them all out.
      Ask FixBot
      • Use the other side of the puller to start working on the switches. Press the 2 clips on the top and bottom side of the switches with the hooks, then pull.
      Ask FixBot
      • The stabilizers can be removed by pushing the clips on each side, then pulling the stabilizer out.
      Ask FixBot
      • There's 7 screws on each side of the keyboard for this step. Remove all the screws and place them somewhere safe!
      Ask FixBot
      • It's time to open up the Raise. Lift the back plate from the top plate carefully, then use a screwdriver to gently push the tabs holding the PCB cable in place - then pull the cable out.
      Ask FixBot
      • Each PCB has 4 screws. Remove them and lift the PCBs from the top plate. Make sure to place these somewhere soft and safe!
      Ask FixBot
      • Lastly, you'll find a smaller, low-profile PCB attached to the each side of the base. Unscrew the 2 screws to remove it.
      Ask FixBot
Dygma
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 24
All Time: 1,005
