Up to 20% off select tools
Durofix RV332 Bit Chuck Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
92
All Time:
1,259
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. Durofix RV332 Bit Chuck Replacement, Bit Chuck: step 1, image 1 of 1
      • Remove the six 13 mm casing screws with the #0 Phillips screwdriver.
      Ask FixBot
    2. Durofix RV332 Bit Chuck Replacement: step 2, image 1 of 2 Durofix RV332 Bit Chuck Replacement: step 2, image 2 of 2
      • Separate the screwdriver casing halves with the plastic opening tool.
      Ask FixBot
    3. Durofix RV332 Bit Chuck Replacement: step 3, image 1 of 1
      • Slide the bit chuck assembly out from the casing half.
      Ask FixBot
    4. Durofix RV332 Bit Chuck Replacement: step 4, image 1 of 1
      • Apply a dab of grease to the end of the drill motor coupler.
      Ask FixBot
    5. Durofix RV332 Bit Chuck Replacement: step 5, image 1 of 1
      • Insert new bit chuck assembly into the drill casing.
      Ask FixBot
Author
with
Tyler Vincent
503 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 92
All Time: 1,259
