Up to 20% off select tools
Durofix RV332 Battery Replacement
Views: 3.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
115
All Time:
3,911
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Part # INR18650-13P
    1. Durofix RV332 Battery Replacement, Battery: step 1, image 1 of 3 Durofix RV332 Battery Replacement, Battery: step 1, image 2 of 3 Durofix RV332 Battery Replacement, Battery: step 1, image 3 of 3
      • Remove the six 13mm case screws with a #0 phillips screwdriver.
      • Separate the screwdriver housing with a plastic opening tool.
      • Remove battery casing half to expose screwdriver internals.
      Ask FixBot
    2. Durofix RV332 Battery Replacement: step 2, image 1 of 2 Durofix RV332 Battery Replacement: step 2, image 2 of 2
      • Locate battery
      • Remove battery, printed circuit board, LED, and motor assembly from screwdriver casing.
      Ask FixBot
    3. Durofix RV332 Battery Replacement: step 3, image 1 of 1
      • Using side cutters, cut the red and black wires connecting the battery to the printed circuit board just after the shrink wrap tubing.
      • Strip the ends of the wires attached to the printed circuit board 1/4 inch above the ends of the cut wires.
      • Solder the new battery to the stripped wires attached to the printed circuit board.
      • Wrap the newly soldered connections with electrical tape.
      Ask FixBot
3 other people completed this guide.
Author
with
Brennan Wade
130 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 115
All Time: 3,911
