Ducky One 3 SF Keycaps and Switches Replacement
  1. Ducky One 3 SF Keycaps and Switches Replacement, Keycaps and Switches: step 1, image 1 of 2 Ducky One 3 SF Keycaps and Switches Replacement, Keycaps and Switches: step 1, image 2 of 2
    • Disconnect the cable from your keyboard.
    • Place the keyboard on a flat and stable surface.
    Ask FixBot
  2. Ducky One 3 SF Keycaps and Switches Replacement: step 2, image 1 of 3 Ducky One 3 SF Keycaps and Switches Replacement: step 2, image 2 of 3 Ducky One 3 SF Keycaps and Switches Replacement: step 2, image 3 of 3
    • Use the switch puller to remove the keycap from the keyboard.
    • Remove all of the keycaps you need to replace or clean.
    Ask FixBot
  3. Ducky One 3 SF Keycaps and Switches Replacement: step 3, image 1 of 2 Ducky One 3 SF Keycaps and Switches Replacement: step 3, image 2 of 2
    • Place the keycaps in a container.
    Ask FixBot
  4. Ducky One 3 SF Keycaps and Switches Replacement: step 4, image 1 of 3 Ducky One 3 SF Keycaps and Switches Replacement: step 4, image 2 of 3 Ducky One 3 SF Keycaps and Switches Replacement: step 4, image 3 of 3
    • Use a key switch puller to secure the switch at the top and bottom.
    • Pull the switch away from the keyboard.
    • Ensure the switch puller is positioned and secured between the switch and the keyboard to prevent any damage to the switch.
    Ask FixBot
  5. Ducky One 3 SF Keycaps and Switches Replacement: step 5, image 1 of 1
    • Place all of the switches from the keyboard in a container.
    Ask FixBot
  6. Ducky One 3 SF Keycaps and Switches Replacement: step 6, image 1 of 1
    • Use a dust blower to remove loose debris from your keyboard.
    • Use a foam tipped swab and Isopropyl Alcohol to clean any residue, oils, or grime from the keyboard.
    • Make sure the keyboard is completely dry before replacing the switches and keycaps.
    Ask FixBot
  7. Ducky One 3 SF Keycaps and Switches Replacement: step 7, image 1 of 1
    • Soak the keycaps in soapy water.
    • Remove all dirt or debris from each keycap.
    Ask FixBot
  8. Ducky One 3 SF Keycaps and Switches Replacement: step 8, image 1 of 1
    • Let the keycaps sit for 10-20 minutes to disinfect.
    • Rinse the keycaps with water.
    • Place them on a towel and use a cloth to remove excess water.
    • Leave the keycaps to air dry.
    • Ensure that the keycaps are completely dry before proceeding to the next step.
    Ask FixBot
  9. Ducky One 3 SF Keycaps and Switches Replacement: step 9, image 1 of 3 Ducky One 3 SF Keycaps and Switches Replacement: step 9, image 2 of 3 Ducky One 3 SF Keycaps and Switches Replacement: step 9, image 3 of 3
    • Insert the new switch into the corresponding holes in the keyboard and push the switch into position.
    • Make sure that the switch pins line up correctly with the holes on the keyboard so they don't get bent or damaged.
    • Continue the process until all switches are in place.
    Ask FixBot
  10. Ducky One 3 SF Keycaps and Switches Replacement: step 10, image 1 of 3 Ducky One 3 SF Keycaps and Switches Replacement: step 10, image 2 of 3 Ducky One 3 SF Keycaps and Switches Replacement: step 10, image 3 of 3
    • Replace each keycap in the correct position and press onto the key switch.
    • Use the following website to confirm both the correct positioning and functionality of the keycap.
    Ask FixBot
Hopefully these steps were clear and useful to you!
Tony Lee
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 49
All Time: 1,210
