Up to 20% off select tools
DualShock 4 Charging Port Replacement
Views: 362K
View statistics:
Past 24 Hours:
47
Past 7 Days:
241
Past 30 Days:
1,055
All Time:
362,139
Comments: 72
38 comments on steps, 34 guide comments.
Go to guide comments
Completed: 111
111 people have marked this guide "completed." Will you be next?
Favorites: 20
20 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 40 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
This guide provides a step-by-step process of how to replace a charging port in the DualShock 4 controller.
    1. DualShock 4 Charging Port Replacement, Controller: step 1, image 1 of 1
      • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
      • Be careful loosening the screws, using the wrong sized screwdriver, or letting the screwdriver slip can permanently damage the screw heads, making removal extremely difficult.
      Ask FixBot
    2. DualShock 4 Charging Port Replacement: step 2, image 1 of 3 DualShock 4 Charging Port Replacement: step 2, image 2 of 3 DualShock 4 Charging Port Replacement: step 2, image 3 of 3
      • Four fragile plastic clips hold the casing together. You can see their locations more clearly in this guide.
      • The clips help hold the seams together. If you break these clips, the controller will still work.
      • Beginning with the left handle:
      • Pinch the left handle of the controller to introduce an opening.
      • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
      • Pull down on tool to pry open the casing.
      • Repeat these steps for the right handle.
      Ask FixBot
    3. DualShock 4 Charging Port Replacement: step 3, image 1 of 3 DualShock 4 Charging Port Replacement: step 3, image 2 of 3 DualShock 4 Charging Port Replacement: step 3, image 3 of 3
      • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
      • Share button
      • Options button
      • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
      • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
      • 2 Trigger Springs
      • 1 Grey Reset Button Extension
      Ask FixBot
    1. DualShock 4 Charging Port Replacement, Charging Port: step 4, image 1 of 3 DualShock 4 Charging Port Replacement, Charging Port: step 4, image 2 of 3 DualShock 4 Charging Port Replacement, Charging Port: step 4, image 3 of 3
      • Detach the motherboard ribbon connecting the two sides of the controller by using your fingers.
      • After the two halves are separated, place the top of the controller off to the side.
      Ask FixBot
    2. DualShock 4 Charging Port Replacement: step 5, image 1 of 3 DualShock 4 Charging Port Replacement: step 5, image 2 of 3 DualShock 4 Charging Port Replacement: step 5, image 3 of 3
      • Remove the two screws holding the sub-assembly together. Then use the blunt forceps to grab the 2 inch black plastic connector labeled in the picture with the red box.
      • Use the blunt forceps to grab the 2 inch white piece of plastic labeled with the orange box.
      Ask FixBot
    3. DualShock 4 Charging Port Replacement: step 6, image 1 of 3 DualShock 4 Charging Port Replacement: step 6, image 2 of 3 DualShock 4 Charging Port Replacement: step 6, image 3 of 3
      • With the clear piece of plastic pushed in, take the transparent white piece out from the top of the controller.
      • Keep the clear plastic piece on the controller, but keep it pushed down to provide room for charger port replacement.
      • Use the Philips #00 Screwdriver to unscrew the two 4.0 mm screws that attach the charging port to the rear cover.
      Ask FixBot
    4. DualShock 4 Charging Port Replacement: step 7, image 1 of 3 DualShock 4 Charging Port Replacement: step 7, image 2 of 3 DualShock 4 Charging Port Replacement: step 7, image 3 of 3
      • With the blunt forceps remove the top part of the black tape connecting the charging port to the plastic portion of the controller.
      • Grab the PCB of the charging port from the side and pull upwards slowly to remove from the controller.
      • Do NOT pull the blue PCB rapidly upwards; instead move the piece side to side to create some free space between the controller and PCB.
      Ask FixBot
111 other people completed this guide.
Author
with
Bijan Vakilifathi
1,937 Reputation
1 Guide authored
Cal Poly, Team 6-21, Maness Winter 2014 Member of Cal Poly, Team 6-21, Maness Winter 2014
CPSU-MANESS-W14S6G21
4 Members
84 Guides authored
34 Guide Comments
Where can i get the USB charger part from? mine is damaged so the lightbar and charger doesnt work but it will still connect to my PS4 until the battery runs out.
Matthew - Reply Share
Did you get it repaired? I need help with mine
Ken Wood - Reply Share
@kenwood58802 i dont know
hunter - Reply Share
Where can you get a new DualShock 4 Charging Port Replacement?
Tony - Reply Share
Have you found them?
jee - Reply Share
Past 24 Hours: 47
Past 7 Days: 241
Past 30 Days: 1,055
All Time: 362,139
