Introduction
Go to step 1 ↓Follow this guide to replace the charging assembly on a Sony DualShock 4 CUH-ZCT2 controller.
Parts
Tools
Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
Gently pry the rear panel off of the front panel until they become partially separated.
Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
Use an opening tool or spudger to separate the white plastic bar from the rear panel.
Use a Phillips screwdriver to remove the 4.4 mm-long screw from the charging assembly.
29 other people completed this guide.
3 Guide Comments
Question:
I have a ps4 controller model CUH-ZCT2U. My charging board model is jds 050.
Can I buy the jds 055 charging board and put that in? Is the jds 050 and the jds 055 charging board interchangeable?
I can't seem to find the jds 050 charging boards anywhere. Only the jds 055. Any help would be very much appreciated. Thanks.
I have not tested the JDS-055 and JDS-050 in a ZCT2U so I cannot guarantee it will work. However, visually they appear to be the same part made by a different manufacturer. I suspect that it will work, but understand that it’s a gamble and make sure the store you buy from has a good return policy like iFixit. If you can wait, add yourself to the notify list for the JDS-050 and order once they become available again.
Great guide but the correct controller model is CUH-ZCT2U. The title has it as CHU-ZCT2U.
