DualShock 4 CHU-ZCT2U Disassembly
Views: 27K
View statistics:
Past 24 Hours:
18
Past 7 Days:
173
Past 30 Days:
737
All Time:
27,329
Comments: 1
1 comment on steps.
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide will walk you through the steps to disassemble the PlayStation 4's DualShock 4, model CHU-ZCT2U. This might be necessary to replace anything from the internal rechargeable battery to the joysticks and anything in between.
Tools
    1. DualShock 4 CHU-ZCT2U Disassembly, First Screws: step 1, image 1 of 2 DualShock 4 CHU-ZCT2U Disassembly, First Screws: step 1, image 2 of 2
      • All the screws are the same in the controller (Phillips's head).
      Ask FixBot
    2. DualShock 4 CHU-ZCT2U Disassembly, Opening the Case: step 2, image 1 of 1
      • Use a plastic spudger to open the case. Try not to scratch the plastic.
      Ask FixBot
    3. DualShock 4 CHU-ZCT2U Disassembly, Separate the 2 halves: step 3, image 1 of 2 DualShock 4 CHU-ZCT2U Disassembly, Separate the 2 halves: step 3, image 2 of 2
      • Be careful opening the case because there is a ribbon cable holding the 3 halves together.
      • The plastic for the lightbar will look different from mine because it's fragile and it broke.
      Ask FixBot
    4. DualShock 4 CHU-ZCT2U Disassembly, Battery: step 4, image 1 of 2 DualShock 4 CHU-ZCT2U Disassembly, Battery: step 4, image 2 of 2
      • Remove the battery and the screw underneath it.
      Ask FixBot
    5. DualShock 4 CHU-ZCT2U Disassembly, Touchpad Ribbon Cable: step 5, image 1 of 1
      • The ribbon cable slots through the rectangular hole in the plastic beneath.
      Ask FixBot
    6. DualShock 4 CHU-ZCT2U Disassembly, Board: step 6, image 1 of 1
      • Remove the board.
      Ask FixBot
    7. DualShock 4 CHU-ZCT2U Disassembly, You Are Done!: step 7, image 1 of 1
      • You're finished with your DualShock 4 dissasembly!
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. If there are any issues, please tell me as this is my first guide
12 other people completed this guide.
Mintyboi 88
376 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 18
Past 7 Days: 173
Past 30 Days: 737
All Time: 27,329
