DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement
  1. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Check your controller model: step 1, image 1 of 1
    • Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
    • If you have the second generation DualShock 4, model CUH-ZCT2U, use these guides.
    Ask FixBot
  2. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unfasten the rear case: step 2, image 1 of 2 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unfasten the rear case: step 2, image 2 of 2
    Tool used on this step:
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • If you need to stabilize your controller during this repair, lay it on a soft surface such as a microfiber cloth.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
    Ask FixBot
  3. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the L1 button: step 3, image 1 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the L1 button: step 3, image 2 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the L1 button: step 3, image 3 of 3
    • Use an opening pick to pry each corner of the L1 button from the front case.
    • Cover the button to prevent it from ejecting out of your workspace.
    • Remove the button.
    Ask FixBot
  4. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the R1 button: step 4, image 1 of 1
    • Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
    Ask FixBot
  5. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unclip the rear case: step 5, image 1 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unclip the rear case: step 5, image 2 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unclip the rear case: step 5, image 3 of 3
    • Six plastic clips secure the rear case to the front case. The next four steps demonstrate how to release these clips before you can open the controller.
    • Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
    • Slide your pick toward the handle and pry up to release the first clip.
    • Repeat this procedure on the other side of the controller to release the second clip.
    Ask FixBot
  6. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: step 6, image 1 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: step 6, image 2 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: step 6, image 3 of 3
    • Two more clips secure the rear case near the extension port and the headphone jack.
    • Insert your opening pick between the front case and rear case at either side of the ports.
    • Twist your pick to unclip this section of the rear case from the front case.
    • If the rear case feels stuck, insert and twist your pick from different angles.
    • Don't open the controller yet, as it's still held together by two very delicate clips near the triggers.
    Ask FixBot
  7. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: step 7, image 1 of 1
    • The final two clips are very delicate, and must be disengaged from inside the controller. If you break them, don't worry—it won't affect this repair or your controllers functionality.
    • Locate the clips by looking through the gap above the R2 or L2 buttons.
    Ask FixBot
  8. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: step 8, image 1 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: step 8, image 2 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: step 8, image 3 of 3
    • Insert the point of a spudger through the gap above the R2 button and push the retaining clip outward.
    • While pushing the clip outward, slowly pull the rear case away from the front case until you feel them separate.
    • Don't fully open the controller until each of the R2 and L2 clips have been disengaged.
    • Repeat this procedure for the clip near the L2 button.
    Ask FixBot
  9. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the rear case: step 9, image 1 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the rear case: step 9, image 2 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the rear case: step 9, image 3 of 3
    • Press the R2 button and slide the rear case over it.
    Ask FixBot
  10. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: step 10, image 1 of 1
    • Press the L2 button and slide the rear case over it.
    Ask FixBot
  11. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: step 11, image 1 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: step 11, image 2 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: step 11, image 3 of 3
    • Flip the rear case over the top of the controller and lay it down, being careful not to strain the interconnect cable.
    Ask FixBot
  12. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Disconnect the interconnect cable: step 12, image 1 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Disconnect the interconnect cable: step 12, image 2 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Disconnect the interconnect cable: step 12, image 3 of 3
    Buy
    • Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
    • During reassembly, reconnect the cable with its blue pull tab facing the outside of the controller.
    Ask FixBot
  13. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unfasten the light guide bracket: step 13, image 1 of 1
    • Use your Phillips screwdriver to remove the two 6.4 mm screws securing the light guide bracket to the rear case.
    Ask FixBot
  14. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light bar bracket: step 14, image 1 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light bar bracket: step 14, image 2 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light bar bracket: step 14, image 3 of 3
    • Remove the black spacer and white bracket from the light guide.
    Ask FixBot
  15. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Peel the foam pads: step 15, image 1 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Peel the foam pads: step 15, image 2 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Peel the foam pads: step 15, image 3 of 3
    • Peel both foam pads from the light guide.
    Ask FixBot
  16. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light guide: step 16, image 1 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light guide: step 16, image 2 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light guide: step 16, image 3 of 3
    • Grab and lift the light guide from its alignment pegs on the rear case.
    • Remove the light guide.
    Ask FixBot
  17. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light diffuser: step 17, image 1 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light diffuser: step 17, image 2 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light diffuser: step 17, image 3 of 3
    • Push the light diffuser through the inside of the rear case and remove it.
    Ask FixBot
  18. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unfasten the charging assembly: step 18, image 1 of 1
    • Use your Phillips screwdriver to remove the two 4.6 mm screws securing the charging assembly to the rear case.
    Ask FixBot
  19. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the charging assembly: step 19, image 1 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the charging assembly: step 19, image 2 of 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the charging assembly: step 19, image 3 of 3
    • Grab and lift the charging assembly from its alignment pegs on the rear case.
    • Remove the charging assembly.
    Ask FixBot
7 other people completed this guide.
Clay Eickemeyer
105,388 Reputation
472 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
19,790 Guides authored
0 Guide Comments
Past 24 Hours: 32
Past 7 Days: 162
Past 30 Days: 530
All Time: 15,068
