Up to 20% off select tools
DualShock 3 Front Shell Cover Replacement
Views: 8.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
52
Past 30 Days:
243
All Time:
8,833
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a worn out, broken or damaged shell of a DualShock 3 controller.
The DualShock 3 weighs about 192 grams and the product dimensions are 15.98 X 5.99 X 9.98 cm. It has a connection port USB mini B but also utilizes Bluetooth technology wireless connection for seamless gameplay.
The following procedure will require disassembling the controller and assembling it back after replacing the damaged front shell which may be caused by breaking when dropped one too many times on the ground or from dislodged joy sticks due to friction. This may lead to damage of the interior of the controller such as the motherboard, battery or motors for example.
Before beginning make sure to disconnect from any external power source like the console.
    1. DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: step 1, image 1 of 2 DualShock 3 Front Shell Cover Replacement, Front Shell Cover.: step 1, image 2 of 2
      • Flip the controller over and locate the five 7.2mm Phillips #0 screws securing the rear cover to the front cover.
      Ask FixBot
    2. DualShock 3 Front Shell Cover Replacement: step 2, image 1 of 3 DualShock 3 Front Shell Cover Replacement: step 2, image 2 of 3 DualShock 3 Front Shell Cover Replacement: step 2, image 3 of 3
      • Using the Phillips #0 screwdriver, remove the five screws holding the rear/back cover in place.
      Ask FixBot
    3. DualShock 3 Front Shell Cover Replacement: step 3, image 1 of 2 DualShock 3 Front Shell Cover Replacement: step 3, image 2 of 2
      • Gently lift the rear cover away from the rest of the controller starting from the bottom side adjacent to the analog stick controllers.
      • Push gently by sliding the rear back forward towards the top edge of the dual shock controller to prevent tripping the two bottom triggers labelled (2).
      Ask FixBot
    4. DualShock 3 Front Shell Cover Replacement: step 4, image 1 of 1
      • Lift the rear cover off of the controller to expose the interior.
      Ask FixBot
    5. DualShock 3 Front Shell Cover Replacement: step 5, image 1 of 3 DualShock 3 Front Shell Cover Replacement: step 5, image 2 of 3 DualShock 3 Front Shell Cover Replacement: step 5, image 3 of 3
      • Carefully detach or disconnect the lithium polymer battery from the motherboard.
      • The wires are fragile, be careful not to break them when pulling out the battery as they can break easily.
      Ask FixBot
    6. DualShock 3 Front Shell Cover Replacement: step 6, image 1 of 3 DualShock 3 Front Shell Cover Replacement: step 6, image 2 of 3 DualShock 3 Front Shell Cover Replacement: step 6, image 3 of 3
      • Use the Phillips #0 screwdriver to remove five 7.2 mm screws from the motherboard.
      • Lift the motherboard, vibration motors and analog module joysticks pads all in one connection, away from the shell.
      Ask FixBot
    7. DualShock 3 Front Shell Cover Replacement: step 7, image 1 of 2 DualShock 3 Front Shell Cover Replacement: step 7, image 2 of 2
      • Carefully lift the rubber or plastic part holding the button triggers labelled (2) in place.
      • Be careful not to strip the plastic rubber holding the triggers in place.
      • Slide the trigger button retainers away from the front shell. Set them aside.
      Ask FixBot
    8. DualShock 3 Front Shell Cover Replacement: step 8, image 1 of 1
      • Set aside the colored buttons and lift the white rubber part holding the Dpad buttons in place to securely remove it.
      Ask FixBot
4 other people completed this guide.
Author
with
Joseph Wambui
253 Reputation
1 Guide authored
1 Guide Comment
The original 6 axis controller I got with my PS3 back in the day has different size screws than the gold plated one I got a few years later. They're about 3 mm longer too
Gregory Hedges - Reply Share
Past 24 Hours: 2
Past 7 Days: 52
Past 30 Days: 243
All Time: 8,833
