Up to 20% off select tools
DualShock 2 Disassembly
Views: 91K
View statistics:
Past 24 Hours:
37
Past 7 Days:
229
Past 30 Days:
899
All Time:
91,271
Comments: 13
6 comments on steps, 7 guide comments.
Go to guide comments
Completed: 48
48 people have marked this guide "completed." Will you be next?
Favorites: 15
15 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. DualShock 2 Disassembly, DualShock 2 Disassembly: step 1, image 1 of 2 DualShock 2 Disassembly, DualShock 2 Disassembly: step 1, image 2 of 2
      • First, check that the connection port of your controller (whether wireless or not) has all the pins.
      • If you have a wired controller (a controller with a cable that connects directly to your console) try bending it in different directions. This may reconnect broken connections within the controller cable and could be a temporary fix.
      Ask FixBot
    2. DualShock 2 Disassembly: step 2, image 1 of 2 DualShock 2 Disassembly: step 2, image 2 of 2
      • Flip Over Controller and remove all 6 screws from the bottom of the controller.
      Ask FixBot
    3. DualShock 2 Disassembly: step 3, image 1 of 2 DualShock 2 Disassembly: step 3, image 2 of 2
      • Once the screws are removed, carefully pry the controller open with your hands.
      • Remove the screw holding the circuit board in place.
      Ask FixBot
    4. DualShock 2 Disassembly: step 4, image 1 of 1
      • Carefully remove the circuit board from the front cover of the controller.
      Ask FixBot
    5. DualShock 2 Disassembly: step 5, image 1 of 1
      • Analyze the rubber pads for any debris that may be getting in the way of the black pads. These make an electrical connection on the pad and may not be contacting properly.
      Ask FixBot
    6. DualShock 2 Disassembly: step 6, image 1 of 1
      • Examine the flexible trigger board itself for any dirt or debris that could get in the rubber button pad's way.
      Ask FixBot
    7. DualShock 2 Disassembly: step 7, image 1 of 1
      • Check the connection of the flexible trigger board to the main circuit board of your controller.
      Ask FixBot
    8. DualShock 2 Disassembly: step 8, image 1 of 1
      • If the previous steps are all covered and you are still facing difficulties in getting your buttons to work, consider replacing the main circuit board or flexible trigger board.
      Ask FixBot
    9. DualShock 2 Disassembly: step 9, image 1 of 1
      • Reverse the disassembly steps until the controller is back to its original state. Plug the controller into the console and test whether the fix worked.
      Ask FixBot
Finish Line
48 other people completed this guide.
Author
with
Peder Hertel
1,503 Reputation
1 Guide authored
Cal Poly, Team 17-5, Green Fall 2015 Member of Cal Poly, Team 17-5, Green Fall 2015
CPSU-GREEN-F15S17G5
4 Members
36 Guides authored
7 Guide Comments
Dualshock 2 controllers, model A and H, are having 8 pins, not 9. Your first Step is false and rarely wires are the cause of the problem.
Eva Langley - Reply Share
No my Dual-shock 2 controller has 9 pins so you are wrong he is right man.
Adam Bolyard - Reply Share
Eva Langley is correct, some of these controllers have only 8 pins, not 9. I myself can conformed this because I just recently opened one of two brand new fresh out of the box Sony original equipment controllers that I purchased (for a little less than $10 a piece) during a clearance sale at my local Sears just before they went out of business. So Eva is NOT wrong. I still have the second one still in the box and before anyone ask, I don’t won’t to sale. I purchased them because I have had both my original controllers go out after they were sitting up for a few years without use. My game units are very well taken care of but the controllers of the PS2 just stopped working and finding a definitive answer to why this happens is STILL very elusive in 2019.
byordsilp - Reply Share
After opening one of these, the R2 and L2 buttons don't feel right, is there a way to fix this?
Fridtjof Riibe - Reply Share
Try to put R2 and L2 after you close the shell. The buttons have clips that hold on position after you insert them .
Alex SC - Reply Share
Past 24 Hours: 37
Past 7 Days: 229
Past 30 Days: 899
All Time: 91,271
