DualShock 2 D-Pad Replacement
    1. DualShock 2 D-Pad Replacement, D-Pad: step 1, image 1 of 3 DualShock 2 D-Pad Replacement, D-Pad: step 1, image 2 of 3 DualShock 2 D-Pad Replacement, D-Pad: step 1, image 3 of 3
      • Turn the controller over.
      • Unscrew the six screws using your Phillips #00 screwdriver.
      Ask FixBot
    2. DualShock 2 D-Pad Replacement: step 2, image 1 of 3 DualShock 2 D-Pad Replacement: step 2, image 2 of 3 DualShock 2 D-Pad Replacement: step 2, image 3 of 3
      • Remove the back cover from the controller.
      • Slide the triggers off by pulling the trigger off the controller and repeat for another side.
      Ask FixBot
    3. DualShock 2 D-Pad Replacement: step 3, image 1 of 3 DualShock 2 D-Pad Replacement: step 3, image 2 of 3 DualShock 2 D-Pad Replacement: step 3, image 3 of 3
      • Remove the circuit board carefully.
      • Make sure not to touch any vital components and only grab them by the side.
      Ask FixBot
    4. DualShock 2 D-Pad Replacement: step 4, image 1 of 3 DualShock 2 D-Pad Replacement: step 4, image 2 of 3 DualShock 2 D-Pad Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the yellow rubber from the D-pad.
      • Remove the black plastic bracket with a pair of tweezers.
      Ask FixBot
    5. DualShock 2 D-Pad Replacement: step 5, image 1 of 3 DualShock 2 D-Pad Replacement: step 5, image 2 of 3 DualShock 2 D-Pad Replacement: step 5, image 3 of 3
      • Remove the broken D-pad from the controller carefully.
      Ask FixBot
    6. DualShock 2 D-Pad Replacement: step 6, image 1 of 3 DualShock 2 D-Pad Replacement: step 6, image 2 of 3 DualShock 2 D-Pad Replacement: step 6, image 3 of 3
      • Put the replacement D-pad in the controller.
      • Make sure to get replacement parts designed for your controller as sizes may vary.
      • Put the plastic bracket back on carefully.
      Ask FixBot
    7. DualShock 2 D-Pad Replacement: step 7, image 1 of 3 DualShock 2 D-Pad Replacement: step 7, image 2 of 3 DualShock 2 D-Pad Replacement: step 7, image 3 of 3
      • Replace the yellow rubber.
      • Carefully insert the circuit board and reclip the triggers.
      • Make sure to insert the analog sticks through the designed opening.
      • Insert the back cover back in place.
      Ask FixBot
    8. DualShock 2 D-Pad Replacement: step 8, image 1 of 3 DualShock 2 D-Pad Replacement: step 8, image 2 of 3 DualShock 2 D-Pad Replacement: step 8, image 3 of 3
      • Screw the back cover on again clockwise.
      • Test D-pad to make sure its in working order.
      Ask FixBot
Enjoy your new D-pad.
7 other people completed this guide.
Gilberto Rosales
337 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 18
Past 7 Days: 106
Past 30 Days: 495
All Time: 13,838
