DualSense Edge Front Trim Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
117
All Time:
1,378
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
Follow this guide to replace, change, or upgrade the front trim on your Sony DualSense Edge controller.
Tools
  • Spudger
    4.9
    Optional
    1. DualSense Edge Front Trim Replacement, Remove the front trim: step 1, image 1 of 3 DualSense Edge Front Trim Replacement, Remove the front trim: step 1, image 2 of 3 DualSense Edge Front Trim Replacement, Remove the front trim: step 1, image 3 of 3
      • Place the controller on a work surface with the joysticks facing down.
      • Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
      • If the front trim doesn't fall open, make sure the front trim has room to fall down and the Release tab is pushed all the way to the left.
      • Lift the controller up, leaving the front trim on the table.
      • During reassembly, insert the front trim at an angle so the top slots in first, then lower the trim into place and snap it onto the controller.
      Ask FixBot
Spencer Pennington
27,671 Reputation
125 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,142 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 117
All Time: 1,378
